Old 13th July 2004, 04:59 AM   #1
JinMTVT is offline JinMTVT  Canada
Default Subwoofer amplifier goals and decisions ..
I've been searching for a good thread that lists all the information
on building a sub/bass amplifier and it's constraints ...
So i would like to ask you all knowledge people ,
to list and talk about the details implicated in building a
good subwoofer amplifier in general
( not for a particular sub unit )
What are the limitations in this kind of amplifier?
What can we "cut" to save because of absence of high frequencies ( this amp needs to be good working up to 1KHz max)
Wich is the best method for low Hz power and precision ?
From what i read, our ears do not perceive good resolution in the 500hz and lower region, so could we compromise sound qualiyt for Oumph and power without any perceived degradation in sound quality ?
what kind of design is best suited for this application...
and also specify electronics that require special needs for lower Hz region ( PSU requirements? sotrage caps? wiring ? current? )
Thanks all for your time!
Old 13th July 2004, 11:29 AM   #2
hi
for starters you have to take into consideration the driver - your amp should be rated way higher than the driver - to avoid clipping damage to the driver
next is the input circuitry consideration - this is where i find most people turning a blind eye a powered sub is not an amp and spk in a box
you have to be good at the input circuitry - 24 db cross over beow 200 hz + active bass linear correction network + a good quality parametric equalizer + a bass boost
if you opt for the linear bass correction network it will give you linear bass spl upto 20 hz that requires heavy amplification + power supply
best choice for such an amp will be a rugged - mosfet - more in parallel the better regardless of the power rating
the power supply should be bifiliar winding primary + secondary = with 2 bridge rectifiers and lots of capacitance 1,00,000 for starters per rail
and the va best at 2 X (times) the power rating
if you go in for all this the next would be the box - you need a real rock solid enclosure
then you can really push lows as much as you like
suranjan
transducer design engineer
Old 13th July 2004, 11:04 PM   #3
thank you for the info!
I don't really understand what you are talking about in terms of input circuitry...is low pass with quality harder to realise than a high pass filter?
personally my next project for sub is a 15 or 18" transfer line
with an external amplifier ( might just sit on top of it )
something in the 8 to 10' long enclosure ..typical taper TL design
i do not have any good resssources for the driver yet, so i do not know of any specs ..
this will be ultimatl played in conjunction of a pair of ESL pannels
for md and highs, and the crossover point shoould be set in the 500hz region ( 500 to 700hz )
Capacitance storage is really needed that much ?
why is bass harder to drive than highs?
is it because of the excursion of the drivers that asks for more current?
paralell mosfet is a la "slone" optimos design right?
this is a trade off for power on higher distort?
is there any parts of amplification that we do not need to take care of when working only with sub 1Khz ?
thanks again
Old 14th July 2004, 12:03 AM   #4
Default low freq. amp design
A good sub amp is usually direct coupled to the speaker. Best to use op-amps for the active low-pass filters for the input, can make the Fc adjustable with a pot. Most sub woofers don't respond well above 100Hz, and as freq. increases, so does the inductance reactance of the speaker coil. The most important thing is that it has a stable DC bias. If you use an OP-AMP for the differential amp stage, a very stable DC bias is possible, and you get no
Don't expect to get high freq. responce from an OP-AMP diff. circuit on account of the slew rate. But for low freq., this may work well.
Anyway this can seriously simplify your project.
Decisions... P101 vs. P3A vs. SKA RyanW Solid State 34 3rd November 2006 08:33 PM
sub decisions v1d9uy Subwoofers 3 30th July 2006 02:54 PM
Power Transformers. Decisions kff322 Tubes / Valves 8 23rd March 2006 09:24 PM
Decisions, Decisions - Help me select iron kstylianos Tubes / Valves 7 14th February 2006 12:05 AM
Newbie design goals: how low/loud? NogginBoink Subwoofers 32 3rd August 2005 11:10 AM
Page generated in 0.09253 seconds (75.09% PHP - 24.91% MySQL) with 10 queries
