Current Source <- how to optimize?
Old 12th July 2004, 10:32 AM   #1
EE is offline EE  Germany
Default Current Source <- how to optimize?
To the audio gurus:
I'm just learning audio circuit design. For the input stage of a power amplifier, I need a constant current source. I know I can use a simple resistor, but this will not be optimal I guess.
The picture below shows the simplest possible approach. How can this be improved / optimized (only regarding sound)?
Old 12th July 2004, 05:16 PM   #2
KlausB is offline KlausB  Germany
KlausB's Avatar
Hi EE,
the way you set up the CS looks OK. Adding a cap parallel to the zener diode might reduce noise. If you want the CS even more stable you can add a cascoding transistor. But I cannot tell you if this really would improve the sonic quality.
KlausB
Old 12th July 2004, 05:51 PM   #3
jam is offline jam  United States
jam's Avatar
Replace R2 with a current source and the zener with a string of diodes.
Jam
Old 12th July 2004, 06:46 PM   #4
OliverD is offline OliverD  Germany
OliverD's Avatar
I prefer LEDs as voltage references in a CCS. Noise and temp. coeff. are better than a zener or string of "normal" diodes.
A simple current source for the reference element can be built using a FET and a resistor. If you need two current sources, one on each rail, you can of course use this for both sides.
Generally, a high hfe for T1 improves performance. A darlington might help. The 2SA1376 is a good choice, I think.
Here's the current source from my preamp which I like very much:
Old 12th July 2004, 10:59 PM   #5
jaycee is offline jaycee  United Kingdom
http://www.4qdtec.com/csm.html
I generally use figure 3 in my designs.
Old 29th December 2004, 03:28 PM   #6
Jef Patat is offline Jef Patat  Belgium
I'm doing some research on this topic to design my first amplifier. After reading a lot it I came to the conclusion that a two transistor constant current source is the best option, for an image I refer to my website http://users.pandora.be/jef_patat/au...t%20source.htm
kind regards, de jef
Visit Jef's Palace at http://www.jefspalace.be to comment my personal project
Old 30th December 2004, 12:18 AM   #7
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
OlivierD
for me it is hard to imagine more sophisticated current source than yours
but do them REALLY metter as far as sound quality is concerned?
Old 30th December 2004, 03:32 AM   #8
LineSource is offline LineSource  United States
LineSource's Avatar
For symmetrical dual differential front-end stages a minor DC offset can be nulled by tugging on the two current sources. This avoids summing the amplifier feedback with an opamp integrator as is often done.
Old 30th December 2004, 07:32 AM   #9
Default does it REALY matter?
I'm not for sure if it makes a lot of difference, I just started designing my first amp.
It only appears to me that the current source I will use gives best results so I think it's the best choice, and beside 4 resistors one cap and two transistors is not the end of the world.
It matters slightly in psrr and cmrr so I stick to my choice.
kind regards, jef
Old 30th December 2004, 07:49 AM   #10
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Current Source &amp;lt;- how to optimize?
Default Re: Current Source <- how to optimize?
Originally posted by EE
To the audio gurus:
You can check some of my stuff but if you use these searchwords
current source
current source cascode
current source cascode wilson mirror
MAT02
Use these words in different combinations when you are using www.google.com you come up with tons of info. Sorry not to be at much help right now. It's a big topic.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Current Source &amp;lt;- how to optimize?Hide this!Advertise here!
BOZ with current source? Decker Pass Labs 2 9th May 2007 03:06 PM
Low Current Source gingertube Tubes / Valves 5 15th November 2005 09:48 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 12:54 PM
R21? and Current Source AC Current Gain macka Pass Labs 9 20th May 2002 08:58 PM
