volume controll in the feedback loop
Old 11th July 2004, 03:19 PM   #21
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Sam,
Do you have a schematic diagram of the switching thing?
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 11th July 2004, 04:09 PM   #22
sam9 is offline sam9  United States
sam9's Avatar
janneman,
This ia all I have:
www.accuphase.com/pdf/p-5000_3.pdf
There is a schematic of sorts but I doubt it has the details you want. In any case, I would think it could be done by simply switching the Lower Arm resistor. The biggest concern would be the physical signal path as that is a potential entry point for noise and cross talk.
Old 11th July 2004, 08:51 PM   #23
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
link doesn't work.
Old 11th July 2004, 09:55 PM   #24
djk is offline djk
R.I.P
djk's Avatar
SAE used feedback loop gain switching in several of their models.
http://wardsweb.org/audio/docs/MK%20...schematic1.jpg
Not the best scan, but readable.
Note that the lower arm resistor is 1K8 with the switched values in parallel with this, if the switch fails it goes to a low gain state.
Old 11th July 2004, 10:11 PM   #25
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Originally posted by JasonL
link doesn't work.
Try this:
http://www.accuphase.com/pdf/p-5000_e.pdf
volume controll in the feedback loopHide this!Advertise here!
feedback loop rmenger Instruments and Amps 4 21st October 2006 07:04 PM
feedback loop rmenger Parts 0 29th July 2004 01:24 PM
ZEN V4 without feedback loop Selfmade Pass Labs 8 20th February 2003 03:38 PM
Feedback Loop help KevinLee Solid State 4 1st December 2002 01:39 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
