volume controll in the feedback loop
Old 10th July 2004, 06:25 PM   #11
johnf is offline johnf  Germany
johnf's Avatar
To add another possible gotcha to the list, I wonder if mixing in a potentiometer with the gain-setting resistors might shorten its life. Some pots, such as those in the Alps RK27 series, expect to only see AC. In a DC circuit, their sliders can suffer silver ion migration and a shortened life. The Alps application engineer I talked to couldn't get any numbers for an excessive DC bias. I got the impression people are careful not to apply one.
Old 10th July 2004, 08:45 PM   #12
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally posted by sss
what if i'll do i in a pre amp , i think most op amps will be stable from unity gain to ~ 27db
Preamps are there to attenuate the signal, NOT to increase it. Even with the preamp gain at 1, and the power amp at the usual 30, your sound level will be much too high for comfortable listening. It will probably blow out your speakers, if the amp doesn't clip beforehand. Imagine a CD player with a 2V output amplyfied 30 times, that 60V in 8 ohms = 450Watts.
One reason the pot is normally at the input is to let you attenuate the signal 30 or 40 dB to prevent our ears from being blown out.
Jan Didden\
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 11th July 2004, 01:15 AM   #13
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
How many mA can pass through 1 small potentiometer?
Old 11th July 2004, 01:58 AM   #14
Hybrid fourdoor is offline Hybrid fourdoor  United States
Hybrid fourdoor's Avatar
Here read this thread, I asked the same thing....notice how i did the series resistor and pot to eliminate any chance of a short.
Old 11th July 2004, 04:38 AM   #15
BStrum is offline BStrum  United States
Default Inverted Op Amp Pre
I recently completed a preamp using an inverted op amp circuit with a 50K Nobel stereo pot controlling the gain in the feed back leg. The topology whihch always uses maximum input signal does optimize the signal to noise.
I used ADC 825s and set the maimum gain of the Preamp at 6 db (2X input).
I also added a mono L + R output with volume for sub woofer control.
The unit runs off +/- 12 V using AA batteries.
It is very quite and sounds great.
It is currently diving an intersting system.
Bill Strum
Bill Strum
Bstrum@imagematics.com
Old 11th July 2004, 07:25 AM   #16
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Default Re: Inverted Op Amp Pre
thats what i'm trying to say
Old 11th July 2004, 08:06 AM   #17
johnf's Avatar
I couldn't get an answer on that. You might get some ideas if you click on the link marked "Caution" under "Related Informations" on this this Alps page.
Old 11th July 2004, 09:56 AM   #18
djk is offline djk
R.I.P
djk's Avatar
I built an inverting preamp with a 100K Alps pot.
While it sounded great, the pot wore out in a very short time.
Commercial designs like this capacitor couple the wiper and then add an input bias resistor.
Old 11th July 2004, 12:08 PM   #19
mskeete is offline mskeete  United Kingdom
I've built a few preamps with a pot in the feedback loop of an inverting opamp. The pot used to become noising after a few months but I realised one day that I hadn't bothered to add a input capacitor. Once I added the input capcitor and used a fet opamp everything has been OK (so far)
I've also seen a nice non inverting circuit in electronics world december 1995 pg 1012. This uses a 10klin pot. The advantange of this circuit is that the opamp gain is very low when the signal is reduced to 0. See attached
Mark
Old 11th July 2004, 02:50 PM   #20
sam9 is offline sam9  United States
sam9's Avatar
Just a point of interest/curiosity. There is a commercial powrr amp, I think it is AccuPhase, that has switchable gain. It's not a volume control, but rather is supossed to let you match the gain with speaker sensativity. Anyway this shows that there is at least one respectable commercial design that does not consider gain to be completely "untouchable"
volume controll in the feedback loopHide this!Advertise here!
feedback loop rmenger Instruments and Amps 4 21st October 2006 07:04 PM
feedback loop rmenger Parts 0 29th July 2004 01:24 PM
ZEN V4 without feedback loop Selfmade Pass Labs 8 20th February 2003 03:38 PM
Feedback Loop help KevinLee Solid State 4 1st December 2002 01:39 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
