#71 |
Sorry for my last post... was a long day etc.. I hope we can forget that one ok?
So I did the measurements... at 'moderate' levels (not disturbing the neibers)..using a Sennheiser ME67, small JM Labs speakers, Technics new class A int amp, Labview software, PC onboard audio interface, NCH tone generator v2.01. typical I got about -20dB THD at 40Hz and -60dB THD at 400Hz, but as I moved my microphone away (Sennheiser ME67), THD degreased. This indicated that the distortion created in the microphone is dominating.. doing some more tests, I found out that as I moved the microphone away, and simultaneously increas power to the speaker, 3rd H decreased (symm flattend tops), while 2nd H increased. This indicated that the microphone mainly produces 3rd H, and the speaker mainly 2nd H. My conclusion so far is, that acoustic THD measurements are far more difficult because micriphones produce so much distortion. -60dB was my measurements limmit. While I can measure electronical THD down to -105dB easely. To improve on this, I will need a more silenced room, so my noise floor is lower. Then I need to increase the distance to from the mic to the speaker as much as possible, lowering the SPL at the mic, while keeping a good S/N. I'm not sure if I can do that in my home setting. I am especially dissapointed by the fact that the microphone (expensive proffesional item) produces so much THD). Another eye opener? Greetings, Thijs |
#72 |
Hi again,
after some better mic placement strategy, and by momentairely shielding the computer air-fan, I got 80dB dynamic range for acoustic THD tests... This is what I did: first measured: mic appr. 1mtr, 400Hz Vadc = -5.2dBV then mic further away, not aimed to the speaker, Vadc = -27dBV, increase power to speaker ro get again apprx..-6dB. This means I could measure 2 power levels , but get equal SPL at the mic. This means that the measurements chain had to deal with equal signals.. all diffrenecs are from the speaker(and amplifier?) ... THD pretty low level = 0.06%, H2 and H3 allmost equal THD 20dB louder, disturbing neigbers = 1.25% H2 dominating over H3 by 16dB! I could not get any good measurements at 40Hz, at all usefull power levels, the mic distortion was domination.. pfd-files of measurements can ftp-ed is anyone is interested.. greetings, Thijs |
#73 |
This ooooooooh s0 typical,
Finaly somebody does some first hand real experiments, instead of wild speculating and going off topic..... and nobody is interested.. These are the first acoustic speaker THD measurements I have seen in 2-3 years here on diyaudio.com.. but people don't seem to care.... the rather stick to fantasysing on wild speculative theories, than do some real experiments and go from there.. Till??? Kuei Yang Wang ?? anyone? |
#74 | ||
Account Disabled
Logic please. Quote:
#75 |
Thijs,
Thanks for actually measuring something. That is similar to the result I got. I have much distortion in my home made microphone, but this is what I got with my microphone at 1 meter away and a 4 volt (4W RMS or so) driving voltage into my Adire kit speakers: Freq % THD 25 6.3 32 6.7 40 1.7 50 1.38 63 1.08 80 0.73 100 0.52 125 0.34 160 0.20 200 0.28 250 0.32 320 0.62 400 0.96 500 1.88 640 2.49 800 3.20 1000 1.90 1250 1.26 1600 0.44 2000 0.55 2500 0.23 3150 0.16 4000 0.29 5000 0.09 6300 0.10 8000 0.09 10000 0.17 |
#76 |
Thanks guys
Thijs, the reason I didn't answer is simply that your figures tell what I had expected, specially the 2nd/3rd level ratio ! Interesting is also the rise around midrange in Kilentra's measurement ! There might be different reasons. Two that just popped up (and there will be more possibilities): 1.) In a two way system, cone breakup and resonances of the midwoofer exagerate the harmonics of the applied fundamental frequency. 2.) Tweeter distortion due to increased x-max. This could only be avoided with very steep crossover slopes but that comes at a price. But we can generally live with this distortion IMO. The worst culprits regarding sound quality are still the performers and producers in most cases. regards Charles |
#77 | |
Hi all,
Kilentra, nice to see some more measurements! It could be that the base-reflex alignment is such that there is minimum cone movement at 160Hz. This would then acount for the dip in THD at 160Hz. And I agree with phase_A, the increase in thd at mid-freq could be because a other cone (tweeter/mid-driver) is taking over from the base-unit. A mid-driver or tweeter will have far less cone-area, and therefore has much larger cone-movement needed for the same SPL, causing higher THD. To check whether the mic is dominating the THD readings, move the mic around to lower the SPL at its membrame, if THD doesn't drop, mic distortion is not dominationg... Regards, Thijs Millwood Quote:
#78 |
The distortion rise in the midrange confuses me, because these particular woofers (Adire AV8) sound very clear in those ranges but have (relatively) more distortion and unclear sound in the range of 1-3KHz, including the main breakup at 1.2 and 2.4 KHz. I have no idea why my distortion peaks around 800Hz. This particular speaker has 6th order acoustic crossover at 2200Hz, and a bass reflex tuning of 24Hz.
#79 | |
Regards Charles |
#80 | |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Konnichiwa,
If the thesis is "low THD means low audible distortion" the two samples provided as illustration of the point (you can imerse yourself in Earl Geddes's AES paper at your own expense and leisure) provde positive and irrefutable prrof to the contrary, as logic says that if a sampe with a nearly huderfold higher lever of THD sounds much less distorted than the other the thesis must be rejected as false. If low(er) THD correlated with lower percieved distortion the reverse would be true. This is the same a number of people (including Olson, Crowhurst and Shorter) have been beating since the 1950's. The drumbeat says, "down with THD". If you still don't "get it" I am sorry to say that you have again completely fullfilled my expectations of you.... Sayonara |
| Measuring speaker distortion | ak_47_boy | Equipment & Tools | 0 | 12th September 2008 02:22 AM |
| Speaker Workshop Distortion Question | arc2v | Multi-Way | 47 | 27th July 2007 02:38 PM |
| Distortion Measurements with speaker workshop | noodle_snacks | Multi-Way | 1 | 6th September 2006 02:28 AM |
