BJT buffer design, can anyone help
Old 24th May 2002, 07:30 PM   #1
tschrama is offline tschrama  Netherlands
Default BJT buffer design, can anyone help
Hi all!
Thanks for all the humor on the forum: Jocko, Dirty Harry and all the rest!
(how's that rich kid doing?)... but now serious:
I found out that I use only very little voltage when listening in my small room in the evening. Thus I wanted to design a class A voltage folower using BJT's capable of driving 8 ohm speakers and 32 ohm headphones at 0.7 volt RMS. I have come up with this circuit.
Can anyone help me with a improvement on the topology?
Greetings,
Thijs
Old 24th May 2002, 07:58 PM   #2
Jocko Homo is offline Jocko Homo  United States
Banned
Yes, but I am tied up for all while. Sit tight, and I'll whip something up.
Jocko
Old 24th May 2002, 08:59 PM   #3
DarkOne is offline DarkOne  Slovakia
DarkOne's Avatar
I think that your idea is not ideal. Try this
If you want, I can post resistor values next week.
Old 24th May 2002, 10:00 PM   #4
HarryHaller is offline HarryHaller  United States
Banned
Exclamation DarkOne
His speakers are going to love the ~-2V DC offset. Don't try this one at home kids.....
Old 24th May 2002, 10:29 PM   #5
Thanks Jocko.. looking foward to it..I'll sit tight :-)
Hi Darkone: thanks for the schematic, since AC coupling at the ouput is OK for me the offset is no problem, but I would like to try to DC couple the buffer some how..
Hi papa Harry .. us kids allways simulate before firering up.. but thanks for the warning. I just finished reading app note 227 of Nat Sem and this might give some inspiration.. I'm still aiming for a buffer with low component count and reasenable performance. Maybe you've got any ideas?
gr,
Thijs
Old 24th May 2002, 11:57 PM   #6
Banned
How low is the parts count you are aiming for, and how high can the output impedance be? BJT or MOSFET?
A month or so ago......I believe "CAPSLOCK" asked about the so-called diamond buffer. I think the thread faded away. That is an option.
Jocko
Old 25th May 2002, 12:24 AM   #7
Hi Jocko,
Thanks for your interest..
Output impedance needs to be low enough to drive speakers whitout dissipating to much be may be sub-optimal (1 ohm ?). For headphones this doesn't matter that much.
I'm trying to make a small buffer-amp (in size that is). I would like to keep dissipation low and parts count low to keep the whole thing small. I was also thinking about the Hiraga Monster topology I aim at more relaxed spec's I figured I could do with less parts somehow. I was actually also aiming at a lower supply voltage than the +/- 15 Volts as shown in my schematic..that's why I used BJT's, less dissipation, less voltage needed, etc.
I'm really currious about how such a thing would sound. Loud enough?, Bi-amped? It could turn out a nice thingy if it stays simple, cheap, maybe even tri-amping, paralelling for 4Ohm use.. battery driven.. you name it.. it could be very flexible and handy to try things out..
I hope you understand my aim a little bit, I hope it makes sense...
gr,
Thijs
Old 25th May 2002, 02:15 AM   #8
sonnya is offline sonnya  Denmark
sonnya's Avatar
Default Re: DarkOne
Do you think so!? hahhahaahhahahahaaaaaaa ... hhmmrmrmrpppfff hahaha (I am laughing my self to dead!!!!)
Low distortion from a BJT buffer (diamond) => highly linear current gain and a high idlecurrent. of course without feedback!
Sonny
Old 25th May 2002, 03:04 AM   #9
Hi Sonnya and Jocko,
I just read everything I could find on 'diamond buffer'. Great stuff ...nice reading!
I now realize I should use high linear devices (no 2N3055 this time .. I sometimes learn stuff here too) .. and bias heavely... but that's what I want to avoid..
I am aming at 1.6Volt peak to 8 ohm: that's 200mA. In push-pull Class A this needs at least 100mA idle..I don't wanna go higher than 150mA.. else I will need real heatsinks at so on.. I would like to keep idle dissipation under 2 watts.. maybe I'm not realistic.. hmmmm
You see: I have this picture of a nice little, no large heat sink, no complicated circuit, easy regulated power supply, above all great sounding buffer-amp in my head..and it wants to get out!
I wanna build six of them , 4 to try a low volume Bi-Amp set-up and 2 for the Grado's..
oke .. I won't anoy you any more .. back to the simulator again..
gr,
Thijs
Old 27th May 2002, 04:17 PM   #10
I think I'm gonna settle with this one ..
What do you guys think?
Iq is 140mA,
Pq is 660mW/ouput device
BJT buffer design, can anyone helpHide this!Advertise here!
SMD Preamp/Buffer design Wynand Chip Amps 7 23rd January 2006 11:12 AM
Which audio buffer design is the best for Gainclone? gengcard Chip Amps 201 4th September 2004 03:14 PM
gc design q#1 - buffer meta Chip Amps 7 9th July 2004 01:28 AM
Copyright ©1999-2017 diyAudio
