This may be a bit OT, but after looking around, it seemed to not fit in the least here.
One of the things I dread doing the most with some of my vintage audio equipment is replacing burnt out lamps. Not only do I have to nearly tear the entire front of the unit apart, but I also have occasional trouble finding the light lamp as far as voltage, size, and mount are concerned. I think that I am going to start replacing the incandescent bulbs with LEDs. But this presents several issues. While LEDs seem to operate just fine on as little as 1 volt, many of these systems provide 6, 8, 12, or even 36 volts to the lamps, and usually it is AC. It would be enough to wire in some resistors, but I cannot predict on some of these systems just how it would affect other things wiring in a bunch of components like resistors and LEDs. So what would be the best way to replace these bulbs with longer-lasting, more efficient LEDs with minimum impact on the rest of the system? Here is a quick drawing I made of a couple of possible configurations. I think I'm on the right trail, but each one seems to affect the circuit in an adverse way. I also have some much more complex ones drawn out, but that is on paper and I would have to scan them in. Thanks. |
#2 |
Did it Himself
Your first schematic is fine and is the method I would use with the addition of an inverse-connected diode such as 1N41001 across the LED. LEDs can only withstand a few volts of reverse voltage.
#3 |
There are a number of issues to solve. First is the resistor needed to drop the input voltage to something the LED can use. Look for the LEDs with the lowest current requirement. This means the dropping resistor can be smaller, say 1/8 watt. Then you'll need to find a small LED T1 (3mm). Then if its AC you'll need diodes to prevent reverse voltages from getting to the LED.
I think its worthwhile to solder an LED with a diode and a resistor in-line and heat shrink the whole thing and use it as a lamp replacement. It will draw a lot less amps and outlast the lamp. Especially true for tube amps where the lamp probably outdraws small signal tube plate currents. I have extra LEDs if you want to experiment - LMK. Bob |
#4 |
Each LED in parallel requires a separate dropping resistor. LEDS do not all have the same forward voltage drop and if you parallel them directly, the one with the lowest forward voltage drop will hog all the current. It is better with multiple LEDs to have them in series, specially if you have loads of voltage to run them, which it appears you do. With an AC source, use two strings of series LEDs in inverse parallel and you can get away with a single dropping resistor.
Note that you must have some sort of inverse parallel diode, either another LED or something like a 1N4001 because LEDs cannot tolerate very much reverse polarity voltage, only about 3V each. By having inverse parallel series strings, the two strings protect each other. Also note that LEDs do not have the dispersion of incandescent lamps and you will need a lot more. Myself, I find if you replace the incandescent lamps with new ones and put a dropping diode in series with them, while they will be dimmer and slightly yellow, they will last 5 times longer than before.
Dan Fraser |
#5 |
Well, I've taken in to consideration what you guys mentioned and here are a couple more schematics I came up with.
In designs 5 and 6, R3 and R7 (respectively) are there so that the AC source "sees" the same load as three bulbs wired in parallel (or does it matter?). Design 5 is the simplest and seems to get the job done, but I don't know how wild I am rectifying the voltage at this point in the circuit (or, again, does it matter?). I am using white LEDs, and I will be mounting them so they point at the diffuser. ------ I just noticed a potential problem with design 6, as D14, D15, and D16, as they are, could cause some problems. I would wire in a resistor in series with them of the same value as is used with the LEDs; also, I'm removing R7 (it seems like a waste of power...). |
#6 |
Forget the diodes and connect each pair of LEDs in parallel with anodes to cathodes and use one series resistor to feed each pair.
There is no point in connecting a resistor in parallel with a LED. |
#7 |
OK, let's get more technical. A standard white led has a typical forward voltage of 3.7V @ 20mA, which is about the maximum current safe for an unknown white.
As said, one series resistor per string to prevent current hogging and uneven illumination. To calculate the resistor, R = (Supply Voltage - Led Forward Voltage) / Led current (Picking the nearest standard value up) For series LEDs, just add the Vfs, ideally the total Vf should be under 80% of the nominal supply volts to allow room for variation. For AC, the options are a series rectifier diode (to block reverse voltage) or an inverse parallel rectifier or second LED (to bypass reverse voltage). If you're hypersensitive to 50/60Hz flicker, a bridge could be used. For mains level AC, a cap is generally used (0.47uF for 60Hz 110V, 0.33uF for 50Hz 230V) to drop most of the voltage, with a 1k 1W series resistor to limit switch-on charge current in the circuit. Less total heat produced than dropping all the spare volts with a resistor. You can diffuse the light better if so required by roughening up the led surface with sandpaper/emery. Should add that with half-wave rectified AC or inverse-parallel leds you can safely double the led current over the spec DC figures. |
| Electronic Lamps, electricity, i need help, lamps burning, needing procedure | destroyer X | Solid State | 27 | 13th September 2005 09:27 AM |
| Trade my blue LEDs for White LEDs | CaliforniaBob | Swap Meet | 7 | 26th March 2004 07:28 AM |
| LEDs to replace classic Marantz lamps? | purplepeople | Parts | 4 | 20th June 2003 01:25 AM |
| WTT: Blue LEDs for Red & Red/Green LEDs | CaliforniaBob | Swap Meet | 2 | 9th June 2003 02:58 PM |
| Page generated in 0.11975 seconds (79.05% PHP - 20.95% MySQL) with 11 queries |
