Old 7th July 2004, 12:06 PM   #1
Jay is offline Jay  Indonesia
Default LL1660, a match for SK135/J50?
I don't remember that hybrid amp that catched my attention. If I'm not mistaken, it is designed by Guido Tent, using modern MOSFET, a 100mA Lundahl, and a tube.
This amp has a "bad" measurement for distortion (like many transparent tube amps). I don't remember if this amp has version that using old Hitachi MOSFET, but that is exactly what I want:
To build the best sounding amplifier from Hitachi K135/J50.
What I want to know is whether I can use the old Hitachi as direct replacement for the newer MOSFET in that schematic, without doing serious harm to the Hitachi (I'm willing to experiment even without sufficient knowledge, but hopefully I can get some help )
Another one is whether LL1660 of the higher current rating can be used without much different (Because I think the higher one can be re-used for different projects)
Old 7th July 2004, 12:25 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Notice also that K135/J50 differs depending of how old they are. My first amp did deliver 285 watts and when I changed mosfets to newer ones I got 385W! The newer fets had substantially lower Rdson.
BTW: I have approx. 30 pairs left of those "newer" ones and they are forsale.
/Per-Anders (my first name) or P-A as my friends call me
Old 7th July 2004, 12:59 PM   #3
To Per - Anders : The same types ? As I know, Hitachi was declared the same parametres all the time .
Old 7th July 2004, 01:06 PM   #4
peranders's Avatar
Indeed but they had a lot less than 1.7 ohms the later transistors, in fact under 1 ohms!
Old 7th July 2004, 02:10 PM   #5
ekaerin is offline ekaerin  Sweden
ekaerin's Avatar
Also watch out for the threshold voltage. The Hitachis start conducting
from Vgs=0. Blinded by the devices I use at work I had to experience
this the hard way.
/ Regards / Mattias
Old 7th July 2004, 05:08 PM   #6
JFG67 is offline JFG67  France
Default Re: LL1660, a match for SK135/J50?
Hello,
One can know the reference of this recent transistor Hitachi ?
If they is the K1058/J162 they are the same chips inside as the K135/J50.
Can one see this diagram of amplifier ?
@ + Jean-François
Old 7th July 2004, 08:38 PM   #7
analog_sa's Avatar
100mA Lundahl
A 1660 at a 100mA?!
Old 7th July 2004, 09:06 PM   #8
Ultima Thule's Avatar
Hi Per-Anders,
do you know from what date the 2SJ50 and 2SK135 got lower Rds-on?
What's the serial number you have on yours?
Is it possible to recognize the diffrence visually on the transistor package?
mvh Michael
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears"
Michael 29th January 2010
Old 7th July 2004, 09:51 PM   #9
peranders's Avatar
I have no idea how the date code works but from my own experience I can say that the first amp was built 1984 and the second one 1989.
Old 8th July 2004, 04:53 AM   #10
That's very interesting what you have found with the Hitachi, Peranders.
I'm not surprised myself if that is true.
Here is the website for the schematic:
http://www.homestead.com/whaan/files/page3.html
It's not 100mA, Analog_sa, but 10mA. The higher version one is 18mA if
I'm not mistaken. The one used in the Euridice preamp (but with single
secondary I guess). Other main components are 5687, LL1660/10,
Magnatec BUZ900P/905P.
I'm going to use parallelled K135/J50 for the output. That is if I got
the green light
Euridice Preamp with 5842 and LL1660 Maurizio Tubes / Valves 8 21st March 2010 07:53 AM
sowter 9050 or Lundahl LL1660 line out transformer? mwmitchell Tubes / Valves 13 20th March 2010 10:42 AM
Hitachi SJ50/SK135 TO-3 for sale AudioGuy Swap Meet 16 11th September 2005 05:07 PM
Problems Lundahl LL1660 and 6c45 to 6c33 Triode!Need help! barossi Tubes / Valves 6 29th October 2003 10:08 PM
Page generated in 0.11190 seconds (77.56% PHP - 22.44% MySQL) with 10 queries
