Does anyone know what is the opamp being used in this preamp? Thanks
#2 |
The one and only
I have been told it was a Burr Brown 604.
#3 |
604 ? I can't belive, that this " superfirm " should to use this not so much good circuit
#4 |
The one and only
I've played with 604's and 2604's and I've seen worse.
Considering that they're running their volume control through a monolithic multiplier, what op amp do you think would measure up to the job? |
#5 | |
They use AD823 for I/V conversion (after the volume DAC) and discreet output buffers (MAT02EH and MAT03EH) That said, OPA2604 sounds pretty good in that preamp.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#6 |
Here you are (380S):
http://www.andiy.com/sch/38s.jpg
#7 |
Thanks all for clearing my doubts. It looks to me that the 380S uses a combinations of different opamps from BB and AD. I'll go ahead to change the opamp in my 38S and see if it will provide a better performance by just using all 2604s.
Best regards, |
#8 |
How about if you switch the output transistors first. The N° 380s uses MAT 02 and MAT 03 there and to my experience with my Levinson N°380s they seem to do a very big deal in the upgrade...
#9 | |
I think the URL is wrong or blocked. You get an HTTP 404 error. |
#10 |
hi carlmart,
The link is an "old" link posted on 07-07-2004 regards
Greg Erskine |
| Can someone help with Mark Levinson JC-2? | atlantaudiophil | Solid State | 22 | 3rd December 2009 12:16 PM |
| Mark Levinson no:29 | Snorkeltjes | Solid State | 19 | 24th November 2007 12:18 PM |
| Mark Levinson 23 | highviewvideo | Solid State | 6 | 21st December 2006 05:52 PM |
| Mark Levinson ML3 | minorl | Solid State | 0 | 6th July 2004 04:59 PM |
| Mark Levinson ML2 | arnach | Solid State | 7 | 9th April 2001 04:36 PM |
| Page generated in 0.09008 seconds (79.02% PHP - 20.98% MySQL) with 10 queries |
