My Leach amp,take a look
Old 24th May 2002, 08:56 PM   #11
malman is offline malman
Nice work Igor!
it look's great!
Are you satisfied with the sound ???
I raise the same concern as Peranders, and from the look of it it seams that the groundpoint is thetopside of the fasteningbolt of the transformer....
This means that your groudpoint is not at the same potential as the case...
This bolt actually becomes a separate winding of the transformer, about one halv turn.... Ie the topside of the bolt is moving in voltage in refernce to the bottomside of it.....
I have a friend who built a amp with two transformers and used centrumbolts to fasten those and a rail that was mounted on top of these.... This meant that there was a closed circuit of quite good conducting area formed by the bolts, the chassi and the bar.
We had truble understanding why the fuses blew if he had the primarys winded one way until we realised what was going on... , by shifting phase of one transformer primary the problem was solved.....
(What happened was that the bolts and the rail created a shortcicued winding through the two transformes.., by changing phase, the transformes are now working in phase with eachoter instead beeing shortcircued by eachoter...)
Keep the good work up!
Whats up next??
/Klas
Old 25th May 2002, 04:50 AM   #12
Kilowatt is offline Kilowatt  United States
Congradulations! Looks great.
Old 26th May 2002, 01:35 AM   #13
shadow is offline shadow
Sound is great and central ground point is connected to case.I just have separate wire connecting CGP to case.Heatsinks and almost everything metal is connected to CGP.
I must take photos now...nice VU meter with blue light.
That metal thing between speakers...russian heavy cannon,antiaircraft,12mm caliber...nice huh?
Next...probaly class A.
Watching beginnings of social decay....
Virus - Iron Maiden
Old 28th May 2002, 02:07 AM   #14
Default Nothing!?
So...no comments?
Virus - Iron Maiden
Old 6th June 2002, 08:16 AM   #15
Eccu is offline Eccu  Finland
Eccu's Avatar
Nice case design...
right way boy... u sold farm and bougth booze
Old 6th June 2002, 08:20 AM   #16
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Well, you sure did a great job on the chasis. I wish I did something like that for my projects, but I'm unfortunatel too lazy, good 'ol Al for me... If it sounds as good as it looks I'd say you're set.
Old 6th June 2002, 09:19 AM   #17
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
[QUOTE]Originally posted by peranders
[B]shadow, why have you shielded the toroid with copper? Isn't it more sensible to use a magnetic material in order to shield magnetic field? I think it's looks nice with copper though.
If you want to shield a steady magnetic field then use iron or mumetal or some other ferrous stuff. However, if you want to shield a varying magnetic field such as might come out of an EI transformer, use metal that has good electrical conductivity e.g. copper. The stray field induces current into the copper, this current has it's own field which then opposes the stray field. Something like that. Ask Mr Lenz and his Law. Anyway, iron for fixed fields, copper for AC fields.
Also, single point earth is great, but not through transformer hole. There will be a voltage difference between chassis and the top of the bolt.
GP.
Old 6th June 2002, 10:38 AM   #18
Lisandro_P is offline Lisandro_P  Argentina
Lisandro_P's Avatar
Send a message via ICQ to Lisandro_P
Looks great, congratulations!
Old 6th June 2002, 12:48 PM   #19
Thanks for suggestions,i get slight hum maybe that CGP shoud be floating and not attached to the fastening bolt.
I must take pictures now with VU meter i think you like it.
Btw:ALPS pot is worth extra money(30) and i cannot imagine DIY project without one.
Virus - Iron Maiden
My Leach amp,take a lookHide this!Advertise here!
My Leach Amp Clone (LEACH 150) panson_hk Solid State 32 22nd May 2014 12:25 PM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 03:15 PM
anyone have leach PCB? ilyash Group Buys 2 7th September 2007 11:36 AM
Leach Superamp vs Leach 4.5 Samuel Jayaraj Solid State 4 26th October 2002 10:20 AM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 11:16 PM
Copyright ©1999-2017 diyAudio
