Honored to present you, a very good audio brazilian designer - Page 3 - diyAudio
Old 6th July 2004, 02:38 AM   #21
destroyer X's Avatar
Default Now the amplifier, The Quasar one
Consider that was made in 1962!
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg
Old 6th July 2004, 02:40 AM   #22
Default The not finished schematics
The one i have here, has the values completely erased.
Carlos
Old 6th July 2004, 02:47 AM   #23
The one and only
Nelson Pass's Avatar
Ha. Carlos, you are good natured crazy man.
Old 6th July 2004, 02:52 AM   #24
Default Yes, I am, already perceived!
And i think, would be better to open another thread to not interrupt your ideas changing about this subject, the "Timi" amplifiers and discussions correlated.
I feel sorry to make this break.
Next time, i promissed, not to re-introduce another subject inside a thread.
Was a foolish, i know...... sorry to disturb you Nelson.
Go ahead, for us, you are the teacher.
regards,
Carlos
Old 6th July 2004, 03:00 AM   #25
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Triple Darlington can be made to measure better, but my ear leads me back to Darlingtons. I've tried Mosfets as buffers for
BJT outputs, and some reason I've never figured out, I never
liked the results
John curl uses mosfet for the driver, like in parasound cct, but in his darlington the mosfets's source is attached to output via 22ohm resistor.
What is the difference if the driver is attached to output and the driver is not attached to output, in darlington stage?
So, what device for the driver? Bipolars?
Old 6th July 2004, 03:30 AM   #26
The one and only
Default Re: Yes, I am, already perceived!
Pardon, it is me who is rudely interrupting thread with offhand
compliment to you.
Originally posted by lumanauw John curl uses mosfet for the driver, like in parasound cct, but in his darlington the mosfets's source is attached to output via 22ohm resistor.
I would not dispute John Curl under any circumstances. The
low value resistor means high bias for Mosfet (good) and more
intimate connection with output (also good).
pass:/ hates to lose - doesn't argue with Curl
Old 7th July 2004, 02:19 AM   #27
Default Here is the adress to brazilian amplifier schematics
You can download the schematics and have some idea, some of them very old, sixties, and have some (Attack) that was already beeing made.
Gradiente A1 are famous
Polivox PM5000 also
Gradiente HII is very good too.
http://planeta.terra.com.br/educacao...ificadores.htm
regards,
Carlos
What components has to be present on the balanced inputs/outputs of an audio ADC/DAC? skpb Analog Line Level 3 12th October 2006 08:30 PM
Audio Loudspeaker Designer/Engineer Wanted TonyG Multi-Way 4 19th November 2005 05:25 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 09:12 PM
I present you my Aleph3 Yonnat Pass Labs 41 16th January 2004 09:06 PM
Famous Audio Designer Sighting artnyos Everything Else 15 29th September 2002 11:06 AM
Copyright 1999-2017 diyAudio
