Yes, I am, already perceived!
And i think, would be better to open another thread to not interrupt your ideas changing about this subject, the "Timi" amplifiers and discussions correlated.
I feel sorry to make this break.
Next time, i promissed, not to re-introduce another subject inside a thread.
Was a foolish, i know...... sorry to disturb you Nelson.
Go ahead, for us, you are the teacher.
regards,
Carlos
regards,
Carlos
John curl uses mosfet for the driver, like in parasound cct, but in his darlington the mosfets's source is attached to output via 22ohm resistor.Triple Darlington can be made to measure better, but my ear leads me back to Darlingtons. I've tried Mosfets as buffers for
BJT outputs, and some reason I've never figured out, I never
liked the results
What is the difference if the driver is attached to output and the driver is not attached to output, in darlington stage?
So, what device for the driver? Bipolars?
Re: Yes, I am, already perceived!
Pardon, it is me who is rudely interrupting thread with offhand
compliment to you.
I would not dispute John Curl under any circumstances. The
low value resistor means high bias for Mosfet (good) and more
intimate connection with output (also good).
pass:/ hates to lose - doesn't argue with Curl
Nelson Pass said:Ha. Carlos, you are good natured crazy man.
destroyer X said:And i think, would be better to open another thread to not interrupt your ideas changing about this subject, the "Timi" amplifiers and discussions correlated.
compliment to you.
Originally posted by lumanauw John curl uses mosfet for the driver, like in parasound cct, but in his darlington the mosfets's source is attached to output via 22ohm resistor.
Here is the adress to brazilian amplifier schematics
You can download the schematics and have some idea, some of them very old, sixties, and have some (Attack) that was already beeing made.
Gradiente A1 are famous
Polivox PM5000 also
Gradiente HII is very good too.
http://planeta.terra.com.br/educacao/audiolist/amplificadores.htm
regards,
Carlos
Polivox PM5000 also
regards,
Carlos
- Honored to present you, a very good audio brazilian designer
