Old 2nd July 2004, 05:41 PM   #1
wigginjs's Avatar
Default Simple toroidal power supply assembly question
This is regarding the simple power supply topology Leach recommends from his amp (here ). This is what I've come up with so far.
1) Here is the diagram on the side of my toroidal transformer. I'm thinking I need to combine the Blue and Violet wires on the primary winding and connect them to one of the AC pins (and it doesn't matter which?) and take the Brown and Grey wires and connect them to the other AC pin. Then on the secondary windings combine the Red and Orange wires and connect them to the AC ground pin. and then the Yellow wire will be 40VAC and the Black wire will be 40VAC that is opposite polarity of the Yellow wire.
2) I will then connect the yellow wire to one of the AC pins (doesn't matter which one, marked by a ~) on my bridge rectifier and the Black wire to the other AC pin.
3) This will result in +57VDC showing up on the "+" pin of the bridge rectifier and -57VDC showing up on the "-" pin of the bridge rectifier.
4) It should be ok to test this by hooking up the primary wires and connecting the yellow and black secondary wires to their respective pins on the bridge rectifier and NOT hooking the red and orange secondary wires to AC ground. There would also be no filter caps or fuses connected. I should be able to test this setup using a multimeter and measuring the "+" pin on the bridge rectifier with respect to the AC ground pin and get +57VDC and testing the "-" pin on the bridge rectifier with respect to ground and getting -57VDC.
I would very much appreciate it if someone could verify that ALL of the above statements are correct and if they are NOT correct telling me what is wrong with these assumptions. I've never wired a power supply before and I want to be extra careful.
The Four Chairs
DIY Home Theater
32V CT 200VA Toroidal Power Transformer from parts express used for Single Supply? tresch Chip Amps 9 28th February 2009 08:58 AM
Cmoy power supply simple question wiredmonkey Chip Amps 2 17th July 2007 12:44 AM
Toroidal power supply transformers crippledchicken Parts 6 21st June 2006 08:46 PM
simple power supply question zobsky Parts 11 10th April 2004 12:00 PM
simple power supply question..... Luke Pass Labs 5 31st March 2004 06:22 AM
Page generated in 0.06675 seconds (68.83% PHP - 31.17% MySQL) with 10 queries
