The interesting Luxman stage - Page 4 - diyAudio
Old 22nd May 2002, 09:35 PM   #31
The one and only
Nelson Pass's Avatar
Was that bubbles or boobies?
"Touriga Nacional" . It's on the shelf next to Coors
at the store here in Foresthill.....
Old 22nd May 2002, 09:42 PM   #32
sonnya is offline sonnya  Denmark
sonnya's Avatar
hahahaha ... Sorry bubbles ... Do you mean this is second class stuff!? .. hahaha
Sonny
Old 22nd May 2002, 11:11 PM   #33
Tube_Dude's Avatar
Hello Sonnya :
"Herdade do Esporo" and "Touriga Nacional" are portughese wines...they are very inexpensive here in Portugal. Im glad that at least we are known for our wines because for our amplifiers nobody know us.
And for you Mr Nelson if you send me one of yours amplifiers i will
send you the same weight in bottles of that splendid wine!!
Jorge
Old 22nd May 2002, 11:22 PM   #34
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
Default Re: DIYers
Damn, I read this and spit out my coke laughing so hard . You guys are a riot!
mlloyd1
Originally posted by HarryHaller
No taste, no money, and lots of opionions......
Old 22nd May 2002, 11:32 PM   #35
Banned
Angry Re. DYIers
Shhhhhhhhhhhhh!..................... The prevailing view around here is that I am not funny but just a domineering a**hole.... Besides, what makes you think I wasn't serious. For real humor try:
i need some openions....please give me feed back...speaker design...
Old 22nd May 2002, 11:38 PM   #36
Account Disabled
Thumbs up hail peranders!!
......to much text has been exhausted on the 'simpler is better' urgument.....as you rightly stated...cd players contain tons of active devices after the disk long before signal hits the power amp......the key i think lies in execution...of course gilding the lily can be taken too far...for instance...a constant current source biased by yet another constant current diode!!
However, a sound design philosophy, grounded in solid engineering principals, and followed through to its logical conclusion usually delivers the goods in sonic terms.........
Old 22nd May 2002, 11:48 PM   #37
Banned
cd players contains tons of active devices long before signal hits the power amp
I thought in minimum the analog signal hits a hand full of switched (very good calibrated?) constant current sources and a resistor which isnt really active, normaly it may see something like one opamp after the currentsouces instead of this resistor. that is something like an "current -elektrometeramplifier" (I-V converter)
this is about that much of active elements as it may see in a very minimalistic chain behind the CDP.
Old 22nd May 2002, 11:57 PM   #38
Banned
Default for instance...a constant current source biased by yet another constant current diode
How do you do that? Can you post a schematic? Is this the same thing as a cascode current source? I'm serious man post a schematic please! I really want try this circuit. How does it measure? What is the output impedance for a 4mA crrent source?Do you have Spice models?
"However, a sound design philosophy, grounded in solid engineering principals, and followed through to its logical conclusion usually delivers the goods in sonic terms........."
Yep... and if frogs had wings they wouldn't bump thier butts on the ground.....
Old 23rd May 2002, 12:10 AM   #39
Account Disabled
Thumbs up dear harry
no need for sarcasm old chap...see attached for example of pointless misuse of components...a constant current source...whose biasing zener has a constant current established by jfet current diode....to be found in some elektor designs...satisfied monsieur harry haller?
Old 23rd May 2002, 12:12 AM   #40
Banned
Harry: Im not professional in this buisiness and the board is called "DIYaudio" and not "closed club of proff. audio EEs"
Im not good enough in your language too understand everything of the information you posted, espacially whats humor and wahts serios to take. OK.
As im a hobbyist i cant measure or give u special data, but look this:
http://www.daisy-laser.nl/homeoptics/tda1305t.pdf
u see a datasheet of a audio DAC.
look on page 4 the block diagram.
everything ecept one analog filter first order is included (C1) on the chip.
Everything analog signal will see are the sources where its generated and the op on the chip. output of the CDP is direkt behind the C. no more buffers or stages needed, signal is about 1,42V RMS at "Vollaussteuerung"
Please correct me if im wrong, i not insist this is right, but its the way i understand it this moment.
luxman a-377 jobmeel Swap Meet 0 11th February 2008 07:22 PM
interesting amp & interesting problem m6tt Tubes / Valves 9 14th August 2007 06:28 PM
Interesting output stage idea keantoken Solid State 18 15th November 2006 11:41 PM
Interesting challenge:GU 50 output stage! Le Basseur Tubes / Valves 10 15th October 2004 07:04 AM
Copyright 1999-2017 diyAudio
