how to hook up sub to Nady power amp?
Old 1st July 2004, 03:42 PM   #1
needtubes is offline needtubes  United States
Default how to hook up sub to Nady power amp?
I have a Nady Audio XA-1100 and have had it powering my sub for some time now. My sub is a DPL12, which is dual voice coil, so I hooked up one channel per voice coil. Each channel driving its 8-ohm load never got hot. But, I just feel that this could be bad for the driver if one VC isn't getting the same amount of power as the other.
So, I paralleled the VC's and hooked them to A channel only. A channel got quite warm when playing a lot, loudly. I didn't really want it to be warm... it has fans that run continuously (which are VERY annoying) and when it gets warm, the fans kick into high gear, which is even mroe annoying.
So, I decided to bridge the amp, thinking that maybe if both channels were used equally, it wouldn't get hot. The info sheets are located here. I am assuming from this diagram that when you select bridge, you take the output from both positive leads. Correct? Well, that is what I have done... and it is still getting very warm. Sounds really good, though.
Are there any dangers to running it bridged at all times? Which hookup method would you use and why? Thanks
Old 1st July 2004, 04:24 PM   #2
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
First: A woofer with two WC's are made to have each stereo channel connected to their own WC. If one WC gets a little hotter than the other makes no problems
Second: Your amp gets hot, because paralleling the two 8 Ohms WC's gives 4 Ohms. Your amplifier now sees halv the impedanse then before, and therefore it gets hotter than before
Last: Your bridging is right, however why only hear the bass of one stereo channel ??? Bridging is entended for use, if you have two amplifiers, each bridged and powering only one channel
I hope this has been some kind of help
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 1st July 2004, 04:39 PM   #3
R.I.P.
Bridging your amplifier and connecting it to the DLP12 with both
coils in series should be the same as connecting each channel
to each voice coil, though you guarantee currents are equal.
Bridging into both coils in parrallel is OK as the amplifier is
specified to work into 2 ohms per channel and 4 ohm bridged,
(4 ohms bridged - each channel sees 2 ohm loading)
but IMO its a farly heavy load for the amplifier.
If you want it to run cooler connect the coils in series.
Only connect the coils in parrallel if the above isn't loud enough.
srten.
how to hook up sub to Nady power amp?Hide this!Advertise here!
Hook-up Wire for Hard Wiring a Power Amp? vdi_nenna Solid State 10 1st April 2008 05:07 PM
FS: Blueprint 1503 15" subwoofer and Nady Audio XA-1100 power amp needtubes Swap Meet 8 21st August 2007 10:36 PM
Anyone familiar with Nady XA-300? whatsnext Solid State 1 4th October 2006 02:00 AM
Want to re-box several si t amps in one box. How do I hook up to one power supply? ExJxC Class D 7 22nd September 2005 09:27 PM
wiring nady amp Fazorcat Subwoofers 4 22nd February 2005 11:15 PM
Copyright ©1999-2017 diyAudio
