looking for a "tube-like" amp
Old 30th June 2004, 01:54 PM   #1
LilMik is offline LilMik  Honduras
Question looking for a "tube-like" amp
hello,
i like the sound of tube amps but i do not have the money to buy one and
i do not like the high voltages, that's why i don't want to build one.
well, my money is limited and my knowledge is limited.
i am looking for a solid state amp with a "valve-like" sound. my speakers a pretty efficient
with 100 db and easy to drive, they have 8 ohm.
can you suggest me a good solid state amplifier with a "tube-like" sound.
i did see all the pass stuff, and i like the soz. it looks really cool.
have fun
LilMik
Old 30th June 2004, 06:36 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Congratulations, your English is infinitely better than my
German.
Old 30th June 2004, 06:54 PM   #3
Richard C is offline Richard C  United Kingdom
I have never heard a solid state amp that sounds like a tube amp.
Somethng using EL84's would not be expensive and IMO would have the potential to sound better than SS amps costing considerably more.
Old 30th June 2004, 09:49 PM   #4
GRollins is offline GRollins  United States
The words "tube-like" are open to interpretation. Solid state gear doesn't sound like tube gear and probably never will. That said, Nelson's Aleph circuits come as close as anything that you're likely to find schematics for. Very warm. Not the so-called 'accurate' sound (far from accurate if you've ever listened to live music) that is actually due to distortion components. They're also fairly simple circuits to build--no adjustments to have to fret over.
Have fun.
Grey
Old 30th June 2004, 10:54 PM   #5
thylantyr is offline thylantyr  United States
Defy the laws of audiophile...
go prosound amp
or
full range class d or t.
Old 30th June 2004, 11:18 PM   #6
Fuling is offline Fuling  Sweden
Letīs see, you live in Germany and you want cheap tube sound?
Put together something simple by parts from www.askjanfirst.de
Old 1st July 2004, 12:50 AM   #7
Magura is offline Magura  Denmark
Magura's Avatar
Or the real simple and "safe bet" solution, Zen V1. Its got a nice warm sound to it...and you can get PCB's for cheap...ohh, and its cheap and very well documented.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 1st July 2004, 09:34 AM   #8
LilMik, maybe you should say what you mean by "valve sound".
I don't like warm sounding amps whether SS or tube and I think that it's an unfortunate misconception that tube amps typically sound warm and coloured.
Unfortunately a lot of people including some amplifier designers believe that to make SS sound like valves it's simply a case of lowering feedback, increasing second harmonic distortion and possibly even rolling-off the high freqencies a little.
This might make an amplifier sound warm but it doesn't make it sound like a good (but not necessarily expensive) valve amp which will sound cleaner, brighter, more detailed, less coloured and much more dynamic.
Old 1st July 2004, 10:15 AM   #9
Eli Duttman is offline Eli Duttman  United States
LilMik,
Consider building a hybrid amp. Use the 6GM8/ECC86 as the voltage amplifier. The 6GM8 was engineered to be used in automotive applications; it works at LOW voltages. The max. allowable anode voltage for the 6GM8 is 30 V.
Your efficient speakers don't need much power to produce satisfactory listening levels. That makes a SE Class "A" O/P stage built around a single MOSFET "practical". 8 V. RMS O/P into 8 Ohms is 8 W. That's a loud 109 dB. at 1 M. from your speakers.
Eli D.
Old 8th July 2004, 04:30 PM   #10
hello,
thank you all. i am sorry for my late answer. i always thought that
all tube-amps do have this special kind of sound. well, my experience is limited. but after reading
a bit i am not sure anymore. just look at mr. leach's paper TubeVsTrans.pfd.
maybe it's not important if it is
a tube-amp or a "sand"-amp. maybe the design is more important. i do not know. maybe it's
all about a special kind of coloration or second harmonic distortion.
what i mean when i say "tube-like" sound. i had the chance to hear two really old tube amps: a
mcintosch c20 and a marantz amp (dunnow the exakt name, sorry). i could
compare it directly with a mark levinson 332 and a schaefer and rompf asr emitter (a pretty good amp
here in germany, you can buy it for about 8000 euro, i guess). the sound of both tube amps was warm,
clear and really "musical", and pretty aggressiv in a soft, harmonic way, i can not describe it. it was
very, very good.
the levinson was not bad, it was actually pretty good. the bass was better and nirvanas
music for example was way better with the ml, but the ml simply did not have this "musicality".
the asr emitter, it's a class a amp with mosfets, was not as good as the tube-amps, but it was
really nice. it's really hard to explain how something does sound. the emitter does have the sound
of the old tube amps. not as good, but it was there.
now, what i am looking for is a little amp with at least 5 watt and the sound
of a 40 year old tube amp.
have fun
LilMik
looking for a "tube-like" ampHide this!Advertise here!
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 4 9th July 2012 02:25 AM
extend tube sockets, or tube "plugs"? wicked1 Tubes / Valves 18 9th August 2010 11:17 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Looking to "Borrow" an Amplitrex, 539C or other High-End Tube Tester in SE PA Area baileyler Swap Meet 0 14th January 2009 02:07 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 05:28 PM
