New guy on the block thinking class A
Old 30th June 2004, 01:47 PM   #1
mashaffer is offline mashaffer  United States
Default New guy on the block thinking class A
Howdy;
I just joined the DIY Audio fora. I posted on the introductions forum but the short version is...
I earned a BS in electrical engineering in the 1980s and have never really used it. I am currently unemployed so am using some of my time to try relearning the vast amount of forgotten material, which leads me to this post.
I intend to get into tubes but lack of money has me playing with the stuff that I already have in the junk drawer. I have prototyped a class AB power amp of about 10-15W and have it running but until I get the money for the finishing touches I have a 2N3055 laying begging to be put to use.
My plan is to make a small SE class A power amp. I have several small signal transistors of both the NPN and PNP persuasion as well as one N channel JFET. The first version will not use any fancy current sources etc because I want to keep it simple and because I have only one power transistor available. Later on who knows.
Currently I am thinking of using either an NPN or the jFET for an input stage (VD biased CE for the NPN or source bias CS for the jFET) and an emitter follower output stage. I am considering a PNP CE for the driver or using the PNP to make a complimentary darlington with the 2N3055.
Any thoughts on the basic plan?
Also I have been unable to find charateristic curves for the 2N3055. Is there a rule of thumb for setting the bias current in this kind of amp?
Generic Signature
Old 30th June 2004, 02:59 PM   #2
azira is offline azira  United States
Welcome to the forum.
SE class-A output stage, set your bias to about 2x your peak target output current. So, if you want 5-watts into 8-ohms, set it to around 1-amp. Better find a good heatsink though.
For the input stage, you can go with a lot less bias. Common values are 1mA to 5mA. In my oppinion, setting the bias current in the input stage has more to do with getting the output impedance and DC level right for driving your output stage than other stuf.
For a datasheet, check out MJE3055, I think they should be similar devices.
I also suggest looking at the Pass Zen amp. It's a SE class-A amp you might consider adapting.
Danny
Old 1st July 2004, 04:12 AM   #3
Default thanks
Thanks for the input. I have data sheets for the 3055. There are a lot of curves related to max ratings and switching applications but no characteristic curves (Vc v.s. Ic) analogous to the plate curves on a tube. Maybe the devices vary so much that you have to run the traces for each individual device.
In any case we are thinking along the same lines. I was thinking 1 to 1.5A depending on where I end up with PS voltage (probably 15V). For heatsinks the transistor is already mounted on a small four fin heatsink (it was used on a 4 amp 12V power supply) and I have a larger 8 fin heat sink which is about three times the size of the original. I may be able to bolt the existing heat sink to the larger one but I may need to just move it to the new heatsink.
I will check out the Pass. I think that is a single stage mosfet design if I remember right.
I am trying to post an attachment with this. It is a picture of the heatsinks.
Generic Signature
Old 1st July 2004, 04:06 PM   #4
Ah, well, I'm not too familiar with tubes although sometimes I wish I was. I doubt I'll get obsessed with the "tube sound" but they just seem fun to play with.
Anyway, a Vc vs Ic curve would depend on the collector loading. What you're really asking is probably: Ic vs Ib curve since a BJT is a current focused device. And that curve is very dependant on Beta which is completely not a controlable factor. You're better off being aware of what the curves kind of look like and then making sure you stay in the fwd-active region. Mostly you want to try and work around beta as the gain factor in your circuit. gm = Ic/Vt and Av = -gmRc for a CE amp.
1-amp, 15-volts = 15watts dissipated. That heatsink may do it, bigger is better... I found that my first time doing a zen, I way underestimated my power consumption and heatsinking needs. Bang-for-buck your best bet is to go to a computer parts store and try and find a cheap, obsolete Athlon heatsink to start with.
You're right, Pass Zen is a single stage mosfet amp, I was suggesting you make a BJT version, it might be interesting. I'd like to see one. But the Zen uses an active current source so I guess that's not quite what you're thinking yet but it's a good start.
Danny
Old 2nd July 2004, 01:56 AM   #5
Default Like this
This is the kind of curves that I meant (See attachment). I think I will just try setting up for about one amp. I'll have to see what I have in power resistors lying around. Or I guess I could try the light bulb trick ala Pass.
Generic Signature
Old 2nd July 2004, 04:57 AM   #6
Jonathan Bright is offline Jonathan Bright  Australia
Welcome to DIY. You might find inspiration and material in the threads devoted to the Class-A amp of John Linsely Hood. There are a couple I know of and the main one had over 900 posts at the last count. His design is 10-20 watts and the later versions specified 2N3055's. If you have not browsed in this DIY forum before his work is usually refered to by his initials (JLH) and if you put "JLH" and "class A" in "search" you should get several threads. The other place to go is a site maintained by one of the DIY Members and it is devoted to the amp just refered to. Try www.tcaas.btintenet.co.uk. "Class-A amplifier" in Google will give it as the first option (I.E. Geoff's site) and later sites on page one will give you Elliot Sound Products that feature the JLH design and other class-A units. The latter site is in sunny Australia. Jonathan Bright (Australia)
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 2nd July 2004, 06:00 PM   #7
millwood is offline millwood  United States
Account Disabled
the jlh 1969 is a simple circuit to build and has the advantage of higher efficiency. I have tried quite a few versions of it with great results. it can also be done with your existing transistors.
you can also put together one of those Zen amps: they are quite simple. I especially liked the latest Zen with feedback (I have a similar design like it but has only one half. It is in one of those pre-amp threads). the zens are mostly (all?) based on mosfets but you can also use the 3055 as well.
as to datasheet, you can try onsemi or fairchild, to name a few.
Old 2nd July 2004, 09:01 PM   #8
Geoff is offline Geoff  United Kingdom
Originally posted by millwood
you can also put together one of those Zen amps .................. the zens are mostly (all?) based on mosfets but you can also use the 3055 as well.
Really?
Is the 2N3055 a drop-in replacement for the IRFP140? If not, what circuit modifications do you suggest would be necessary to make it work, whilst maintaining similar performance (distortion, output power etc).
Old 3rd July 2004, 01:12 AM   #9
Default Here is where my head is
Jonathan, thanks for the tip on the JLH. I will check it out.
I thought that it might be useful to look at a couple of circuits. The top circuit in the attached jpeg is a priliminary sketch of my thoughts for the class A amp. The bottom circuit is the current state of a class AB prototype on which I am working. I am including this second circuit so that you can get an idea of from whence I am coming. I would welcome comments on both circuits (and my interpretation of them). Please be gentle... I am trying to learn here.
The Class AB Amp:
this is a modification of a design from an old text book. The values in () are the actual values as I built it. The indicated voltages are actual measured values in the prototype. Just noticed that the schematic shows R1 = 50k pot. This has been changed to 100k. Note that the original design used two diodes in place of the 390 ohm bias resistor. I was having trouble getting the right bias with the diodes and so I switched to a resistor (I was using rectifier diodes which may have been the problem). When everything else is sorted out I will probably try using signal diodes (or a single diode with a trim pot).
As it now sits the prototype idles very cool and when played quite loudly the heatsink gets warm but not at all uncomfortable to touch continuously. It sounds fairly good at moderate to high volume levels. If I drive it with a signal low enough that I have to put my ear right up next to the speaker to even hear it I hear some static like distortion (cross-over distortion?).
Given that the amp idles as cool as it does and the distortion at very low signal levels I suspect that I might be more like class B at this point. This may not be a big deal since it will be used as a utility amp for an electronic keyboard but the goal is Class AB.
I am also concerned with the low voltage at the base of Q1 since this will limit the input voltage headroom. I am able to drive it to a nice level with a cassette deck but I would feel more comfortable with a little more voltage swing. I did not increase R3 very much from the original design and I probably should double it to get a bit more headroom (and better Zin) and then readjust R1.
I also note that I could have (should have?) used small signal devices for Q2 and Q3 but the TIPs were handy and I thought that the extra current and power capability would give me some extra leeway. I may change them out and use the TIPs to make another identical channel.
One thing that I had trouble with initially was understanding the purpose and operation of C2. The text book claimed that it was used to decouple the PS by bypassing R6. Now it doesn't look to me like this is the case at all. From other reading that I have done I think that it is used to bootstrap R4. Am I off base here?
The initial circuit did not have the Zobel. I threw that in when I thought that I might be getting ultrasonic oscillation (I still am not sure and I don't have a scope to check it out).
The Class A Circuit (V+ = 15V):
Now be kind... I am doing this in order to learn remember. :-)
Since this is a learning project I thought that I would try something a little different and use an EF output stage and build the first version with no interstage feedback. The circuit shown is my first concept of what it would look like.
Icq3 will be set to approximately 1A. From 2N3055 data sheet hFE@Ic=1A@25deg.C is 90 ==> Ibq3=11mA so Icq2 should be about 100mA to prevent excess loading by Ibq3.
The first thing I notice is that Vcq2 will be (V+/2)+ 0.6 = 8.1V in this case. Now the maximum input to Q2 will be limited by the Quiescent voltage across Re2 which is limited to substantially less that V+/2 due to the requirement that the C-E junction remain reverse biased. This should be OK as long as we give the Q2 stage sufficient gain to bring this up to near the supply voltage(???). Will I be able to get a gain of about 5 in the Q2 stage while still being able to deliver sufficient drive current for Q3? Would I choose Re2 such that Veq2=(V+ - Vbq3)/2 or should I use higher voltage gain in Q2 (and lower Vdrop in Re2) so that I can maximize Vcq2 swing? As you can see I am a little bit confused on how to optimize this.
My initial impulse was to collapse the Q2/Q3 stage into what I would call a complementary darlington pair (like a darlington but using PNP-NPN pair) but unless I am missing something this appears to be impossible with an EF output stage because of the severe limitation on the input voltage (Q2 emitter is at V+). A true darlington using 2 NPN devices possibly?
The pot connection of C4 is for prototyping purposes so that the gain of stage one can be adjusted.
So am I totally out in left field here? Barking up the wrong pole?
Generic Signature
Old 3rd July 2004, 04:24 AM   #10
Default Re: Here is where my head is
That would be called a "CFP" or complementary feedback pair. It's a pretty common type of output stage. While most used strictly for output stages try to create unity gain, there are versions that actually have gain. A CFP wouldn't be a bad idea to try, it looks similar to what you're doing now anyway. So a search on CFP or sziklai pair for more info.
Danny
New guy on the block thinking class AHide this!Advertise here!
I was thinking Hojvaelde Tubes / Valves 5 4th October 2006 07:53 PM
Thinking of starting a 'new' Class D design. Genomerics Class D 15 10th May 2005 05:08 PM
Thinking About Building A Class A Amp, But Have Some Questions li_gangyi Pass Labs 13 16th January 2004 05:28 AM
Copyright ©1999-2017 diyAudio
