Old 29th June 2004, 12:41 PM   #1
wigginjs's Avatar
Default Balanced Inputs on Leach Amp
How would I add the ability to accept a balanced input (via an XLR connector) to the Leach Amp design? Anyone ever done this?
The Four Chairs
DIY Home Theater
Old 29th June 2004, 02:11 PM   #2
pooge is offline pooge  United States
Use an input transformer, a la Jensen JT-11P-1 or the like, and change the input resistor on the Leach to 10K to properly load the transformer.
Old 29th June 2004, 02:27 PM   #3
tool49 is offline tool49  Canada
tool49's Avatar
Or you could also make a small zener supply, regulate it and use the INA134 chip.
Sébastien
Old 29th June 2004, 02:37 PM   #4
wigginjs's Avatar
Sorry, but those answers are a little over my head. I'd perfer to construct something that could intergrate into the existing design (so it still allows the unbalaced input to function) and would not require modifications to the leachamp PCB. Anyone have a diagram of a circuit that could accomplish this?
The Four Chairs
DIY Home Theater
Old 29th June 2004, 02:52 PM   #5
tool49's Avatar
I believe that my solution answers to all your requirements!
Sadly I do not have time right now to go into more details.
Sébastien
Old 29th June 2004, 03:42 PM   #6
Did it Himself
richie00boy's Avatar
See ESP Project for balanced line driver/receiver. You would also need to tap off the rails to power the op-amp circuitry - Rod also has a project for this (simple pre-regulator I think it is).
Old 29th June 2004, 04:39 PM   #7
Well, you're going to have to alter SOMETHING. You have to connect the input to the board. If you don't want to change the input resistor on the board, you can add a 20k resistor across the connectors of the XLR so that it will be in parallel to the 20k input resistor on the Leach. You can find a circuit at the link. It ain't cheap, though. You could also wire the unbalanced input in parallel with the XLR, but don't connect to both inputs at the same time.
Jensen input transformer
Old 30th June 2004, 10:03 AM   #8
djk is offline djk
djk's Avatar
I second the use of a transformer.
Electronic balanced inputs are a waste of time and money.
A lower priced alternative to the Jensen is from EDCOR
http://www.edcorusa.com/sound/matchers/s2s10k_10k.htm
Old 30th June 2004, 01:11 PM   #9
Did it Himself
Whilst transformers are undoubedly the ultimate, for a tenth (maybe even less than that) of the price the electronic version cannot be dismissed, and done properly results can be very good.
Old 30th June 2004, 07:19 PM   #10
The one and only
Nelson Pass's Avatar
Default Re: Balanced Inputs on Leach Amp
As I recall, the Leach is a simple enough differential input, and
is easily adapted to balanced inputs. Check out the discussion
of differential inputs on the A75 article at www.passdiy.com
and you'll see good enough examples.
How do you know if an amp can properly accept balanced inputs? shagone Car Audio 16 8th December 2010 01:55 AM
Balanced vs/ Umbalanced (cables, inputs, ans so on ...) teodorom Everything Else 11 18th November 2008 11:20 AM
XLR (maybe balanced) and RCA amp inputs rick57 Solid State 5 22nd November 2006 11:20 PM
balanced inputs DD_Davo Chip Amps 1 4th February 2006 04:29 PM
Shorting balanced inputs? dantwomey Pass Labs 10 27th April 2003 09:51 AM
Page generated in 0.10498 seconds (78.72% PHP - 21.28% MySQL) with 10 queries
