Old 29th June 2004, 12:07 PM   #1
chlo is offline chlo  United Kingdom
Default I need help!
Hello,
I have a problem with my amplifier (cyrus 7). I connected a CDP to the amp and caused a pop sound on one speaker. The amp is noisy on that speaker since and always produces a pop sound when I select to that input source even I turn the volume at minimal point. I suspect something has burned! Does anyone has experience with this.
Many thanks in advance.
Chlo
Old 29th June 2004, 12:13 PM   #2
boholm is offline boholm  Denmark
boholm's Avatar
Does it make a scratching noise, when you turn the volume?
Best regards
Bo
Old 29th June 2004, 12:29 PM   #3
yes, it gives humping noise on one chanel.
Chlo
Old 29th June 2004, 01:12 PM   #4
boholm's Avatar
It then sounds like you've got DC somewhere. Please check that your amplifier - without the CDP connected - does not scratch turning the volume. If it does, then the amplifier has a DC problem. If not, then the CDP has a DC problem. If you have a voltmeter and know electronics you have a chance of fixing. Otherwise you need qualified help.
Best regards
Bo
Page generated in 0.07542 seconds (69.59% PHP - 30.41% MySQL) with 9 queries
