Big Honkin' Amp Design - Help Me! (Nelson?) - Page 4 - diyAudio
Old 23rd May 2002, 12:42 AM   #31
Warp Engineer
On Holiday
AudioFreak's Avatar
Kilowatt,
and 300V not 300W
NU_NRG,
Nothing you can really do. Assuming both transformers are identical, it's just the inherent inefficiency of a single transformer squared. DO NOT try to join the 2 cores!
Old 23rd May 2002, 12:48 AM   #32
NU_NRG's Avatar
Send a message via ICQ to NU_NRG
Smile me likes warnings...
AudioFreak- Not that i don't believe you, but i've seen some of those over the years... whats the big danger? Over fluxing of the cores?
kilowatt- thanks for your feedback, btw sorry I got off topic with that question...
-Simon
Old 25th May 2002, 04:29 AM   #33
Yes, I meant 300V or course. Typos can happen to the best of us.
Old 25th May 2002, 08:23 AM   #34
frugal-phile(tm)
planet10's Avatar
Default 120->12->12->120
"hook them back to back" if this means 120V AC (prim) -> 12V AV (sec) -> 12V AC (prim) -> 120V AC (sec)
I've seen this done in tube circuits fairly often (using 12V filament transformers) but only for small amps and preamps that only need 120-150 V or with a doubler twice that.
In his case he has a 480 VA (less with the extra transformer losses) isolation transformer.
As to sucking the juice out of the wall, it was done all the time with 5-tube radios, and small console hifis. My 5-buck amp started just that way. I added a 120V isolation trafo from a ground fault isolator to make it safe when i rebuilt it -- sort of at the opposite end of the spectrum from the kilowatts beast at a healthy 1 and a bit watts.
I think it would be more fun to build an amp using the 40A 12+V Rails, than 4A 120V rails.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th May 2002, 02:50 PM   #35
NU_NRG's Avatar
Default interesting idea...
Would it be possible to acheive stable, high power amp with low impedance loads?
A subwofer amp that could drive .25Ohm loads at 500W ???
what do you all think?
-Simon
Old 28th May 2002, 08:49 PM   #36
Yeah Bill F. had a thread about a low impedance amp a while back. He wanted to drive a huge wall of speakers in parallel, but I don't think he wanted very much power. You should check it out.
Tubelab Simple SE with big honkin' Edcors? rknize Tubelab 122 14th February 2011 04:22 AM
Zeny based on Nelson Pass cascode design jh6you Pass Labs 132 30th April 2007 05:21 AM
Big Honkin Tele jaymanaa Tubes / Valves 5 30th April 2006 10:55 AM
Copyright 1999-2017 diyAudio
