Noise when people turn off lights
Old 5th December 2004, 07:19 PM   #11
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
I have a loud "pop" everytime a fluorescent light in the next room gets turned on or off.Doesn't matter which amp I'm using,I always hear it.
I've tried: A decent homebrew power filter built in a 6-outlet strip, a R/C (100 ohms .01uf) across the switch,varistors,etc..
It's always there and I can't get it to go away!
The only thing I havn't tried is replacing the fixture,which may happen soon.
Beware of fluorescent lights,and dimmers,they are noisy creatures!
Infact,a few weeks ago a friend was over and we were playing with something on the scope,and we could see noise on the trace from all the dimmers around the house! just a "notch" on the 60hz background noise..the "notch" would move up and down theside of the sine wave depending on the brightness setting of the dimmer.
Old 5th December 2004, 07:32 PM   #12
karahara is offline karahara  Germany
Send a message via ICQ to karahara
I hear this "pop"noise when lights, which are switched by an "Current draw switch"[stromstoßschalter, Eltako, i don't know the right word], are turned on or off
Old 5th December 2004, 07:42 PM   #13
Bricolo is offline Bricolo  France
Bricolo's Avatar
I had this problem on my computer speakers
try to place a ferrite core around the mains cable, and the same with the input cable (if the cable is thin enough, make some turns around the ferrite)
it worked for me
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 6th December 2004, 04:18 AM   #14
gmphadte is offline gmphadte  India
Fix a .068µF/400VAC capacitor across the primary of the tranformer. Try nearby value for best results.
Fix a capacitor of 2/2.5µF/250VAC at the fluorescent light fitting across the mains.
Gajanan Phadte
Noise when people turn off lightsHide this!Advertise here!
i get hiss noise when the treble is turn up on high?? prorms Solid State 1 7th April 2008 11:00 PM
Why do people listen to people from the industry?? Magura Everything Else 60 14th April 2004 01:34 AM
How can I reduce mechanical turn on and turn off noise? soundNERD Chip Amps 8 28th October 2003 01:43 AM
turn on noise junglejuice Solid State 5 27th October 2002 06:49 AM
