This amp is a:
Sanyo Mosfet DC power amplifier Plus PSS. The amp will work normally then without warning, send the maximum output to the speakers (A or B channel); the circuit breaker kicks in; then it is back to normal for a bit. Any idea or suggestions on how to repair this? Aloha, Neal |
#2 |
Account Disabled
One good reason to change to Pass' Aleph series of amps...particularly the 'o'....no funny spikes on program....
...rather tough to get a grip on that....total absence of such is generaly a hallmark of quality amp..... |
#3 |
Hi Neal,
Check solder connections first. If this still happens, warm up some transistors one by one. They may go open when heated. Do not have your speakers connected when doing this! Next, use some cooling spray and give the transistors a small shot. Wait between transistors as the effect is thermal and may take 20s or so. I have had capacitors & resistors do this too. I track 'em down with a 'scope as I "tease" the unit. The Mosfet output stage doesn't make this any different to troubleshoot than a BJT output amp. -Chris |
#4 |
Thanks for the input. Will take it to a friend's house and run troubleshoot it there.
Aloha, Neal |
| Maximum output with tda2050 | pra3718 | Chip Amps | 11 | 10th August 2009 04:42 PM |
| Driver Choice and Maximum Output | pjpoes | Multi-Way | 7 | 4th March 2009 02:02 PM |
| How do I calculate the maximum output of a driver? | The Paulinator | Subwoofers | 2 | 21st May 2008 01:00 PM |
| Maximum transformer output | RobPhill33 | Everything Else | 4 | 17th March 2003 12:50 AM |
| Page generated in 0.06939 seconds (70.95% PHP - 29.05% MySQL) with 10 queries |
