Old 25th June 2004, 06:27 AM   #1
agp is offline agp  United States
Default Krell Ksa 150 remote trigger
I have several KSA amps that I would like to remotely trigger. On one of the KSA 150's there is a small red dual rockerswitch in the middle of the front pcb that allows you to change the function of the on/off switch. After changing the switch settings, when you plug in the amp it automatically turns on. Unfortunately, none of the other amps has this newer front pcb. Short of buying new boards from Krell ($$$$$) does anyone have any ideas for a mod of the power switch so i could use a 12v trigger or a low voltage relay trigger on the outlet it is plugged into ?
Old 30th March 2005, 12:52 PM   #2
Send a message via MSN to Lord_Magnepan
That is quite interesting, because when i brought my unit from america to germany i had to change one of the red switched from 1-2 so that they both show 2-2 in order to make the unit accept 220V. Do you mean the same 2 red switched right on the front PCB?
-Flo
Old 30th March 2005, 07:02 PM   #3
AndrewT is online now AndrewT  Scotland
the ESP site has a signal sensing switch (relay) to switch on and a delayed off to control power amps.
regards Andrew T.
Remote trigger wiring question GhettoSQ Car Audio 2 7th December 2008 02:12 AM
Krell amp remote pfcs49 Solid State 0 15th April 2008 11:47 PM
Krell trigger and remote link compatibility philbyx Solid State 1 20th June 2004 05:36 PM
Krell FBP 300 link (trigger) cabling philbyx Solid State 0 13th June 2004 01:13 PM
Remote trigger circuit for amp Gaber Solid State 7 1st February 2002 05:25 PM
Page generated in 0.07895 seconds (67.52% PHP - 32.48% MySQL) with 10 queries
