Could anyone tell me what's the difference between the various rectification phases? A while ago I blew a fuse in my preamp and need to replace the rectifier. Turns out it uses a single-phase rectifier (BR-102). I want to upgrade to a soft recovery FRED-type unit, but don't know if they make these in a single-phase design. Which leads me to ask: what is single-phase vs. two or three phases? Is the single-phase design just the standard four diode bridge rectifier? in which case I can use just a standard soft-recovery bridge? Thanks, KT |
#2 |
Yes, a simple 4-diode bridge is a single phase rectifier.
A 3-phase bridge is what you are likely to have in your car alternator, and has more than four diodes. You would only need something like this on mains supplies to produce dc from high-power 3-phase mains feeds for industrial power supplies (perhaps for a MIG or TIG welder). |
#3 | |
A three phase bridge has three ac terminals, and is constructed of six diodes. You can use a 3 phase bridge in place of a single phase one, by using only two of the ac legs. It's capacity will be reduced however, by approximately 1/3rd of the units rating. Cheers, John |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| phases issues | crazyhub | Multi-Way | 2 | 4th January 2008 09:34 AM |
| 6CJ3 rectifier or 6D22S rectifier | 56oval | Tubes / Valves | 10 | 19th April 2007 09:48 AM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Page generated in 0.07607 seconds (71.47% PHP - 28.53% MySQL) with 10 queries |
