small a-class power amp non global nfb
Old 24th June 2004, 10:07 AM   #1
padamiecki is online now padamiecki  Poland
Lightbulb small a-class power amp non global nfb
I would like to introduce my latest projects that I have made.
Those are simple a-class low power amplifiers with only a local feedback, however the amp from the 1st option is almost nfb-free (the natural feedback is only from used parts and is an inherent character oof the used devices).
The amplifiers are enough to home-listening.
The signal from cdplayer was feed through the 47k potentiometer.
I projected those topologies many years ago and last time seen them similar on a French site with mosfets. The world is small! But my first designs used a source resistors (both input and output). Latest do not!
After reading a few posts at diyaudio I decide to minimalise the nfb in fets/mosfets and introduce larger nfb for the bjts.
It was after an article in which there was proven that SE fets suffer from nfb (even a local) and produce high order odd harmonics.
It was shown that the thing with bjts is different: high nfb makes the distortions smaller.
So please look at the attachment.
There are 3 options on it.
1st option: hexfets as output devices: very good sound, fast bass, however I can hear the distortions when higher levels occurred.
2nd option: bjts as output devices: amazing sound but weak damping factor: lazy bass.
3rd option (that I have never build): a mix of above. To build this an experiment with a re value is needed. Probably there is a need to set the currents of hexfet and bjt equal.
I would like to see your comments both of the designs and the sound (30 minutes is enough to build this). How you expect, is there a chance in 3rd option to distortion cancellation and to improve the damping factor (of course yes but how much?)?
For those who wish to build this I wrote a few notes:
1. Output transistors on medium hitsinks,
2. Regulate the potentiometers to get a current through the output transistors at about 1 A and 0VDC at the output, Be carefull during regulating; I have burned at about 10 pairs of hexfets: start tha regulation from 0 ohm on potentiometers!!!
3. The output drift should be at about ±100mV,
regards, Pawel
Old 24th June 2004, 10:28 AM   #2
hera is a more friendly image
regards, Pawel
Old 28th June 2011, 03:27 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
I like it.
The Option 1. with IRF9540/540 MOSFET.
It wilol not have lowest THD and need a well filtered/regulated supply for best result.
Old 28th June 2011, 03:43 PM   #4
Bigun is offline Bigun  Canada
Bigun's Avatar
I've never built with MOSFETs but I remember a paper looking at distortion due to local feedback with FETs, Triodes and BJTs. The BJTs in EF configuration were better than MOSFETs and this is the direction I am going with my own ngb amplifiers at the present time.
Option 3 looks like something I've seen from wavebourn and I talk about it in one of my threads on the Valve forum. A friend of mine tells me it was popular in Russia many years ago. The BJT turns on first (0.7V Vbe) and then the MOSFET comes to the rescue when the BJT hits beta-droop.
It's worth checking out the valve forum, they have explored SS power followers to put after tube voltage amplifiers without nfb.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 28th June 2011, 10:22 PM   #5
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Looks like it will have a [I]lot[I] of gain, and I think you'll have to watch
the bias drift on those IR outputs.
small a-class power amp non global nfbHide this!Advertise here!
Class-A tube amps deprecated in the light of global warming? wakibaki Everything Else 69 27th March 2008 05:34 AM
Small BIG power for not so high-end class D diy’s Joep Zonnebloem Class D 29 29th April 2005 04:39 PM
