Current feedback - Voltage feedback, how do I see the difference?
Old 1st April 2013, 09:38 PM   #771
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Originally Posted by dadod View Post
This is not fair comparison. As CFA you use current conveyor and ideal output stage(as in VFA), but a current conveyor is very load sensitive and with real output stage VFA will produce lower distortion(at least in all my simulation attempts).
BR Damir
Hi Damir,
Why it is not a fair comparison? I'm only comparing the two input stages. The rest is kept the same. Whether it's a real amplifier or not, doesn't matter. It's just a test circuit where the input trannies operate under the same conditions (i.e. same trans-conductance and same ratio between AC current vs idle DC current).
E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht(H.M. van Randwijk)
Old 1st April 2013, 10:44 PM   #772
Bonsai is offline Bonsai  Europe
Originally Posted by Waly View Post
Maybe not, but it is certainly useful to prove the potential (very) high slew rate of CFAs. That is, the "current on demand" property.
Yes, tha is what I meant. Of course the feedback resistors set the closed loop gain - so no discussion there.
I still do not see these things as being equivalent ( i.e. in topological terms) to VFA and prefer to see the feedback as being of the current type. The fact that the gain equation reduces to the same form as that for a VFA should not lead one to abandon the current feedback view. (Kind of like those 2 economists that used math to prove their theories, win the Nobel prize for economics - a misnomer in itself - go out and start an investment company, fail miserably. Someone then points out that their whole theory was based on the wrong premise. Then there was the one that was famously criticized for not using enough math, but seems to have got his theory right.)
Old 1st April 2013, 10:56 PM   #773
Waly is offline Waly  Somaliland
Waly's Avatar
No problem, it's your call to build a fence and place yourself on one side.
I prefer, if possible, a world with less fences, fences obstruct the view and usually require defense (like in the current debate).
Old 2nd April 2013, 01:10 AM   #774
"I prefer, if possible, a world with less fences, fences obstruct the view . . . "
I think we are in complete agreement.
Old 2nd April 2013, 03:47 AM   #775
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
there seems to be an old assumption that good compliments cannot/do not exist in IC opamps. That used to be the case a long time ago, but processes have evolved and in fact the CFA couldnt be made until proccesses were developed to make good compliments. They exist just fine in todays high speed CMFB opamps.
Its just too bad for the DIY'er that such complimentary devices are not available in simple pairs to us.
Thx-RNMarsh
Old 2nd April 2013, 04:50 AM   #776
Richard, you make a good point. However, for discrete designs I think the designer can still get some pretty good results with the available parts. For instance, you can get NPN and PNP pairs matched to with 2% hFE and Vbe from a number of vendors (in SMD packages - but still very solderable ). These are not the complimentary pairs you mention, but sorting through a batch I am sure would yield pairs of closely matching devices. In my two recent CFA design efforts nx-Amplifier: A 100 W class AB CFA Amplifier and Ovation sx-Amplifier I simply used high gain BC547C and BC557C types with good results. No doubt, carefull matching would yield better results, but I no longer have access to an AP to veryify the possible gains. They sound pretty damn fine though.
Most CFA power amps are going to use some form of emitter degeneration which will help mitigate some of the points raised earlier. If you make the assumption that power dissipation of the buffer stage is not a limiting factor (thermal considerations notwithstanding) as is the case of opamps, you can also run the whole thing hard into class A if thats your pursuasion. As Edmond has pointed out, the front end of a CFA can be optimized for very low distortion - I posted an LTSpice line stage design effort of mine up about 3 years ago that got me down into the low hundreds of ppb, and this was achieved with minimal effort (16dB gain, 2V out into 600 Ohms IIRC at 20 kHz). So, a number of us do not recognize CFA's as being poor performers -just different!
Old 2nd April 2013, 06:37 AM   #777
RNMarsh's Avatar
I dont know where the idea that cm circuits dont do well. Its a push-pull family and they do just fine. About 35 years ago, my little CFA idea was simple but had a thd+n that was below .0018%--- the lower limit of the HP test gear of the era. I had to run the little line amp up to +22 and -22v peak to peak to see it rise above that floor [used +/- 24vdc supplies]. Just hand matched a bunch of NPN and PNP on a curve tracer... still the best way. Oh and it used 20dB of fb.
I'd like to see a power amp using cmfb topology of about 450W/8 or more for my use at home. THD <.001%
No, really.
Thx-RNMarsh
Old 2nd April 2013, 10:21 AM   #778
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by Edmond Stuart View Post
Hi Damir,
E.
Hi Edmond,
I simulated your input stage in two mode, as CFA and as pure current conveyor with no feedback, and difference in distortion is very small, 0.031589% for the CFA and 0.045572% for the CC.
My point is that a current conveyor has low distortion by itself and feed back will not improve it much.
Here are my simulations.
BR Damir
Old 2nd April 2013, 10:27 AM   #779
dadod's Avatar
The challenge is to design CFA output amplifier with as low distortion as VFA one, apart slew rate where CFA beat VFA, not just input stage.
Damir
Old 2nd April 2013, 11:10 AM   #780
No, really.
Thx-RNMarsh
350 W is on the drawing board. With AFEC of course
Current feedback - Voltage feedback, how do I see the difference?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
