Current feedback - Voltage feedback, how do I see the difference?
Old 24th March 2013, 04:17 PM   #501
michaelkiwanuka is offline michaelkiwanuka  United Kingdom
Banned
Originally Posted by Bonsai View Post
Michael, you have COMPLETELY missed the point!
No, Bonsai, you've completely missed the point.
Oh, and what, precisely, is the point I've missed?
Old 24th March 2013, 04:18 PM   #502
Banned
Originally Posted by scott wurcer View Post
This is a joke yes?
No.
Old 24th March 2013, 04:30 PM   #503
Waly is offline Waly
"A CFA is a VFA, where the feedback network loading of the amp, at the input (series) node, can't be neglected."
Old 24th March 2013, 04:55 PM   #504
Banned
In other words, the feedback network affects the forward path gain of a so-called "CFA", but this does not alter the fact that all so-called "CFAs" are in fact deeply compromised (for audio applications) VFAs
Old 24th March 2013, 04:59 PM   #505
RNMarsh is online now RNMarsh  United States
RNMarsh's Avatar
Are the formula's for gain the same? They should be if a CFA is a VFA.
They are sufficiently different to describe a fundamentaly different mode of gain operation.
Thx-RNMarsh
Old 24th March 2013, 05:05 PM   #506
To borrow your own language, this is nonsense.
Old 24th March 2013, 05:16 PM   #507
In general no, because of the loading effect, affecting the open loop gain, which in turn may affect (if not large enough) the closed loop gain. However, in certain conditions (both external - gain and internal - topology), the CFA closed loop voltage gain expression can be the same as for a VFA. Look at the LM6172, a CFA in disguise. Of course, then the main characteristic of a CFA, that is the gain independent bandwidth, is lost. You can't have cake and eat it too.
Old 24th March 2013, 05:26 PM   #508
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Did you actually look into that instead of just following your unreliable gut? Do you realise that the current into the low impedance node is NOT determined by its low impedance?
jan
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher
Old 24th March 2013, 05:43 PM   #509
Banned
This so-called "gain indepedent bandwidth" is an electronic sleight of hand because for low closed loop gains a so-called "CFA" sacrifices forward path gain, and, therefore, loop gain to obtain it.
So, attempting to increase negative feedback (loop gain) by reducing the amplifier's closed loop gain accomplishes virtually nothing in terms of overall linearity because the amplifier's first stage gain is simultaneously reduced.
So, of what utility are so-called "CFAs" in audio applications?
Old 24th March 2013, 05:50 PM   #510
Banned
Thx-RNMarsh
Attachment 338158
For a first order analysis, the values of the feedback components appear in the equation for the forward path gain in so-called "CFA", whereas this is not the case in a VFA.
However, this doesn't change the fact that so-called "CFAs" are really compromised VFAs.
Read the section entitled "over compensation" in the figure you posted.
Current feedback - Voltage feedback, how do I see the difference?Hide this!Advertise here!
