Can anyone help me with a circuit for inverting the phaze on a two channel stereo amp and thereby turning it into a sigle channel mono amplifier?
The Audio Control Richter Scale has this feature, but it only does it for one amp....basically for turing a stereo amp into a single channel sub amp. Van Alstine sells this unit, but it's $300 for the kit, and I'd like to do this myself with my own chassis and effort. Thanks Chris |
#2 |
http://sound.westhost.com/project14.htm
But what I would do is probably just use a DRV134 chip straight up.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
Or use SSM2142P.
#4 |
Try this :
http://www.tcaas.btinternet.co.uk/jlh1970.pdf (see last Figure in the article) Very simple, works great. Negligible noise (I used MPSA18 as Q1 but BC550C would also be fine), but make sure you have input caps on the power amp inputs. Patrick |
| A very odd phase inverter- comments? | GordonW | Tubes / Valves | 6 | 16th August 2008 02:05 PM |
| Convert Stereo Headshell To MONO | MZ | Analogue Source | 0 | 6th February 2008 07:24 PM |
| Phase inverter | ThSpeakerDude88 | Tubes / Valves | 37 | 29th August 2007 03:15 PM |
| wanted quickly!!!! a circuit to convert mono to stereo. | sagarverma | Analog Line Level | 4 | 10th May 2006 11:06 AM |
| Mystery (to me) phase inverter? | porkchop61 | Tubes / Valves | 17 | 6th October 2004 11:16 AM |
| Page generated in 0.07120 seconds (75.66% PHP - 24.34% MySQL) with 10 queries |
