Just acquired a Lambda regulated power supply (from a local flea market) that has 5 lablled wiring terminals:
(+s) - sensing (+DCV) - positive floating (Case) - case (-VDC) - negative floating (-s) - sensing. Note that as is I could only see voltage between (+VDC) and (-VDC) but not between (+VDC)(Case) or (-VDC)(Case) due to floating. It is quite easy to wire it as a single (+VDC)(G) or (-VDC)(G) supply by grounding the (-V<->Case) or (+V<->Case) accordingly. Is there a way to get both +ve and -ve rails simultaneously? Plan to use it for an amp project. TIA. |
#2 |
If you design the power amplifiers carefully and make sure that the DC-offset on the output is really low and that the driver bias currents or other biasing currents does not flow into ground you can build a capacitive voltage splitter with a push pull emitter follower to make sure that the midpoint stays within +/-0,7V. Quad uses such a solution in one of their early amps and I have used it with success. The problem is that you end up with half the voltage swing i.e. if the converter delivers 60V you can only achieve +/-30V output swing.
If something that measures good doesn´t sound good, measure again! |
#3 |
The one and only
If not a large amount of current needs to run through the
ground (i.e. a balanced output) then two resistors and a cap (to ground) are sufficient to establish a virtual ground that the circuit can reference. If the load runs to ground so that the current is high, I suggest fairly low value resistors and a really big cap
#4 |
This supply may be suitable for a bridged design using single supply and taking the ground as the signal reference voltage
#5 |
Well, after poking around a bit the PS appears to be a variant of the discontinued LK351
model (Linear PS). It is adjustable from 0-40V (splitting would be 0-20V rail), regulated to ~mV, and can source 18Amp at 40 deg. C. Weighs 95lb. I was interested in its current capability and wanted to try out a multi-channel amp (~8 for home theater) or a two channel Aleph-X for music, which all seems to default to a +/- rail configuration. Would anyone see show stoppers trying to use this PS for the above purposes? Thanks for the responses and suggestions thus far. |
| Floating A2 Bias | ak_47_boy | Tubes / Valves | 7 | 30th October 2007 07:53 AM |
| How to get a 15V floating supply | rtarbell | Power Supplies | 10 | 14th February 2007 04:17 PM |
| Floating the heaters | YoungFred | Tubes / Valves | 2 | 16th September 2006 11:59 AM |
| Floating voltages | eeka chu | Solid State | 12 | 29th January 2004 04:57 PM |
| Floating voltages | eeka chu | Parts | 2 | 27th January 2004 10:10 AM |
| Page generated in 0.08355 seconds (80.92% PHP - 19.08% MySQL) with 10 queries |
