MOX builder’s thread - Page 25 - diyAudio
Old 22nd April 2005, 07:06 PM   #241
Bricolo is offline Bricolo  France
Bricolo's Avatar
I'm sure about that Having all poles placed on the same circle and equally spaced, in the s-plane, is caracteristic of the Butterworth alignment.
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 22nd April 2005, 07:48 PM   #242
Hi Bricolo,
1 pole Butterworth use Q=0.7071
2 pole Butterworth use Q=0.7071
3 pole Butterworth use Q=1 & Q=0.7071
4 pole Butterworth use Q=1.3066 & Q=0.5412
L-R2 use cascade Q=0.7071 ( 2*B1 )
L-R4 use cascade Q=0.7071 ( 2*B2 )
L-R6 use cascade Q=1 & Q=0.7071 ( 2*B3 )
L-R8 use cascade Q=1.3066 & Q=0.5412 ( 2*B4 )
As you said, all these filters are set at the same Xover frequency.
Do you need the gain settings to achieve these Q values?
Have you read LeCleach on xover modification yet?http://freerider.dyndns.org/anlage/LeCleach2.zip Then you have to change frequencies.
Can this mod be modelled on Moxlite?
Has anyone listened to this mod yet?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd April 2005, 08:16 PM   #243
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
For a first order filter, the Q does not apply.
Q can only be defined for a second order function.
\Jens
Old 23rd April 2005, 09:41 AM   #244
Hi Bricolo,
would you like to start a new thread (or wiki) & explain that poles, circles & s-plane theory? and how to use it in practice.
I would like to learn more.
regards Andrew T.
Old 23rd April 2005, 11:20 AM   #245
Bricolo's Avatar
It's not very usefull to set up an audio filter, since everything is already pre-calculated and many tables are available.
But if you want to have a deeper look at the theory, and where those tables come from, you can read those pages:
Do you know what a s-plane is? Basicly, it's a map where your poles and zeros are placed, according to theyr Real and Imaginary part.
This chapter seems good
http://www.phys.ualberta.ca/~gingric...00000000000000
And for Butterworth filters:
http://www.microindustrie.com/dsp/b-dis.htm
Old 23rd April 2005, 11:42 AM   #246
Tables are always normalized to a frequency, when using tables to design a filter, you also should look up frequency scaling as this is needed to calculate the parameters in the non normalized filter.
Frequency scaling "moves" the corner-freq from the normalized frequency to where you want your filter to have it's cornerfrequency.
I hope I make sence
\Jens
Old 2nd May 2005, 10:17 PM   #247
Default Butterworth 4 pole
Hi all,
I have attached an excel spreadsheet to calculate the caps & resistors for a 4 pole low pass filter.
It uses 2 cascaded unity gain stages (moxlite) with staggered Qs of .54 & 1.3 to achieve a total q=0.7071 for Butterworth roll off.
Each stage could be used for odd values of Q if Mox shows the need to tailor the Xover to your speakers.
regards Andrew T.
Old 3rd August 2012, 01:12 PM   #248
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Does anyone have a copy of the MOX II opamp assembly guide? Referenced in post #4.
Thanks,
Vince
I build, therefore I am.
Old 3rd August 2012, 04:41 PM   #249
grimberg's Avatar
Vince,
Here you go.
Anidian Audio - MOX - Opamp assembly page 1
Old 3rd August 2012, 04:54 PM   #250
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
I needed the link, as well. Thanks
I hope tiroth is doing well...
Copyright ©1999-2017 diyAudio
