MOX builder’s thread - Page 14 - diyAudio
Old 5th October 2004, 06:21 AM   #131
Mark25 is offline Mark25  United Kingdom
Mark25's Avatar
Originally posted by JensRasmussen
Hello,......................
Changing the Q to achieve a “bump” in a HP filter in a SUB is one way of making the subwoofer player lower.
\Jens
Thanks for the reply Jens.
I had never considered the above! I'm guessing that the higher ranges of Q (ie above 1) will be of limited use to those staying away from a drivers natural roll-offs, like me.
Interestingly, i currently use an LR aligned active Xover, so there should be some interesting comparisions when i get the MOX built.
Thanks again.
We will pay the price, but we will not count the cost...
Old 20th November 2004, 08:07 AM   #132
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default ...many hours later...
- and still some to go...
Arne K
Don't believe everything you think...
Old 20th November 2004, 11:08 AM   #133
Bricolo is offline Bricolo  France
Bricolo's Avatar
Hi MOX users!
I'm not using the MOX, but I'm working on an active flter too.
I wanted to know: how's your grounding shceme in your active XO? Since there's multiple boards, each one having an output+gnd, input+gnd and power supply+gnd connector, can't this create some ground loops?
Alex
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 20th November 2004, 02:18 PM   #134
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Hello Arne,
Nice one, how about some close ups?
\Jens
Old 20th November 2004, 07:37 PM   #135
DIY !
Cobra2's Avatar
Default By request...
Hello Arne,
\Jens
Arne K
Old 3rd December 2004, 06:31 AM   #136
MBK is offline MBK  Singapore
Default HF rolloff with 100x settings?
Hi all,
I finally got to test my 8 boards. All filter sections are completed, inputs and buffers still to customize.
The results are very good and consistent for the 1x and 10x frequencies.
But at the 100x settings (the 1 nF cap) I have a consistent HF rolloff for the HP section, ca. -1 dB at 20k. The rolloff starts well below 20k, so that the crossover frequency shifts significantly and the HP and LP lines don't cross at -3 dB anymore.
Any ideas as to the cause? I eliminated the following:
- op amps: tested OPA 2134, TL072, NE5532
- input: buffered or unbuffered
- all 8 boards react the same
- soundcard has reference (its other channel)
- input buffer alone, or any HP settings with the 100 nF and 10 nF caps (1x and 10x) are perfect at 0 dB at 20 kHz - so it couldn't be in/out problems anyway.
Whay should the smallest cap cause a HF rolloff in a HP filter?? I can only think of lead inductance or parasitic capacitace to ground.
Pics attached, self explaining I hope. Note especially where the 2000 Hz HP, using 200 Hz x10, has 0 dB at 20 kHz, while the 2500 Hz HP, using 25 Hz at 100x, has -1 dB at 20 kHz. The 25 Hz at x1 or at x10 is perfect at 0 dB at 20 kHz.
MBK
Old 3rd December 2004, 06:33 AM   #137
Default next pic
series of HP frequencies
MBK
Old 3rd December 2004, 12:14 PM   #138
tiroth is offline tiroth  United States
Well, now, this is interesting. Ages ago I posted a similar pic showing the same odd behavior and was really scratching my head over it. To me, it did not look like rolloff--Fc was dead on, and the slope looked to be zero outside the crossover. It just looked like it was -1dB down.
Looking at your post, I also do not think Fc has been shifted when the level is corrected for.
http://www.diyaudio.com/forums/showt...881#post383881
But Jens was unable to duplicate my results! What could be different about his setup and ours?
Old 3rd December 2004, 12:26 PM   #139
Tiroth,
You're right, FC shifts only insofar as now the curves intersect only at higher F - in fact it is due to a loss of gain in the HP. It doesn't shift w/ frequency after it reaches its maximum, so it is likely not stray inductance/capacitance as I speculated. Could be that the formulas for Sallen key make some hidden assumptions which become invalid for certain ratios of caps and resistors... I didn't know/remember that you had the same results...
In retrospect it would have been better (for me) to cut all R values by a factor of, say, 5 (better also for low noise and for op amp balance regarding R on negative vs positive inputs...) and to multiply the caps by 5 (I don't need the 0.1 x setting anyway which would then require a very large cap). Hmm, or I can use an intermediate cap at the 0.1x position. But that would make for odd frequencies.
I guess now the only quick hack is to raise the Q for the HP to compensate. Or to live with it
MBK
Old 3rd December 2004, 12:29 PM   #140
Well, if it is only a difference in level, just increase the gain by 1dB...unless you have drivers with identical sensitivity the interchannel gain won't be the same regardless.
Copyright ©1999-2017 diyAudio
