The Son of Dork (SOD) project is the result of the diyAudio.com multi-channel preamp initiative (The diyAudio.com preamp project!). The project has been split into threads dedicated to discussion of the preamp's different functional units:
- General Discussion (project status, functional requirements) - Active Circuitry - Attenuator - Power Supply - Connections and Layout (including input switching) - Chassis and Construction - Hardware Logic, Controls, Display - Microprocessor (programming, implementation) I will be managing the project as a whole, as well as initially overseeing individual threads. For a background on the project, please see the original thread referenced above. A website dedicated to the project will be located at http://dorkus.org/diy/sod. Let the fun begin! |
#2 |
Looks like another Friday night and not much is going on on the forum (at least in the Dorkus' department). The guys from Portugal are getting wild posting Borberly circuits and since nobody really said anything about construction of the preamp I will post some pictures of the unit I've done 10 years ago. It had a nice switching capabilities, dual mono setup and remote volume.
I understand that the thing Dorkus is planning will be different, however, maybe some people would decide only on two channels and might take some inspiration from here. As you see power supply takes 2/3 of the space. There are two separate transformers which are potted and shielded with copper enclosure. Regulators for ea. channel are on opposite sides. The active circuitry is at the back. |
#3 |
The heart of the preamp is the back pannel. Input and output jacks are mounted there. All the switching is done by relays mounted directly to the jacks and PCB, no wires. Right above the relay board is the metal plate which holds the active circuit. It is potted (I wouldn't do it now but back then I thought that potting would damp vibrations and allow even heat distribution). Beside the active block there is another board wich holds 10 relays which allow to switch the gain of the preamp from 10 dB to 20 dB by changing the feedback resistors. There is more space here and I was planning on mounting additional 2 boards above for active crossover. I never did it. However, vertical mounting of the boards allows for better use of space and shorter connections.
#4 |
i will post some pics of the integrated amp i built last year. it didn't turn out quite as well as i hoped it would (it has a trace of hum and is on the bright side, possibly due to the tinned PCBs i got), but it still sounds quite excellent (better than the Krell integrated my friend has IMHO) and works very well. the construction is not too shabby either, it even has full remote control.
#5 |
Here is the picture of the switching circuit. The relays are switched by rotary switches on the front panel. No logic, no fancy stuff. The volume is of a shunt type, 22k resistor in series, after that motorized Alps to the ground. Some with a quick eye (Apogee?) might notice that there is no AC connection on the back panel. The reason for that is that the back panel is divided for left and right side which contain corresponding inputs and outputs. I didn't want to run AC lines close to sensitive audio circuitry, so I placed the socket on the bottom directly beside the transformers.
#6 |
hp,
those images and construction details are great, but maybe we should save them for the web page? i have plenty of web space, we can post stuff there and link to it. nice pics regardless. cheers, marc |
#7 |
Those pictures might quite well fit the Pass Gallery because the active circuit I used was A75 front end. You can see the way I placed the big electrolytics under the regulators boards. The regulators were taken from ML23.5. The frame for the chassis is made of two aluminum slabs, 1/2" thick, on both sides. The front and back panels (1/8") are screwed to them as well as bottom and top (1/4").
#8 |
I didn't catch your previous suggestion Dorkus. No more images than.
One other thing though. It's nice to place a connection on the back panel for remote switching of all the amps. |
#9 |
HPotter, I'm currently upgrading a preamp to include remote volume control. However, the only circuit I have found that uses standard RC5 type infrared codes to drive a motorised pot is a ready built unit from Michael Percy Audio for $100. This seems very expensive; could you post more details of the arrangement you have used in your preamp?
Thanks, TRWH. |
#10 |
HPotter, what a nice piece of work. Makes me wonder how I could improve the looks of my own projects. Would you care to give some advice?
How did you get the brushed finish on the aluminium? What about the lettering on the front panel, how was that made? Finally: where did you find those good looking control knobs? Thanks, Pekka |
| BOSOZ Chassis Construction | LizardBrain | Pass Labs | 5 | 19th March 2006 05:35 AM |
| chassis construction | theChris | Chip Amps | 19 | 12th January 2006 02:59 AM |
| Son of Dork: General | dorkus | Solid State | 2 | 25th August 2003 12:23 AM |
| Son of Dork: Attenuator | dorkus | Solid State | 65 | 19th April 2003 10:09 PM |
| Son of Dork: Microprocessor | dorkus | Solid State | 43 | 5th August 2002 04:08 PM |
| Page generated in 0.11184 seconds (79.87% PHP - 20.13% MySQL) with 11 queries |
