#111 |
harry, it's the simple pass-MOSFET regulated supply in my power supply thread. i think it is ok, but you mayhave a point about a PS problem... the cable connection between the ps and the circuit is too long and skimpy (3-wire 18 gauge braid, about 3 feet long) so that could be screwing up the bass. i had it that way for prototyping purposes but i should probably replace it with shorter heavier cable. i suspect that may help.
#112 |
since it's related, check out my latest comment in the Attenuator thread:
http://www.diyaudio.com/forums/showt...489#post115489 the MSB preamp i'm using sounds very very good and could be a good active stage/attenuator solution to investigate. |
| Son of Dork: General | dorkus | Solid State | 2 | 25th August 2003 12:23 AM |
| Son of Dork: Attenuator | dorkus | Solid State | 65 | 19th April 2003 10:09 PM |
| Son of Dork: Chassis and Construction | dorkus | Solid State | 18 | 13th December 2002 01:28 PM |
| Son of Dork: Microprocessor | dorkus | Solid State | 43 | 5th August 2002 04:08 PM |
| Son of Dork: Connections and Layout | dorkus | Solid State | 0 | 17th May 2002 09:45 PM |
| Page generated in 0.09592 seconds (63.92% PHP - 36.08% MySQL) with 11 queries |
