Transformer output solid state
Old 3rd April 2007, 01:17 PM   #31
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
This is the amp, Phass RE-2. It uses exotic components, like Jensen output transformer, Sony FETs.
Here, we got a member Rozak that is successfull making this kind of amp (transformer coupled).
Old 3rd April 2007, 02:11 PM   #32
Boris_The_Blade is offline Boris_The_Blade  United States
Boris_The_Blade's Avatar
ahh, thanks anyway. I am curious about this because I would like to try some high-voltage MOSFETs in place of tubes in a push-pull fashion...and this was quite close.
Old 3rd April 2007, 02:22 PM   #33
lumanauw's Avatar
You can search username Rozak, and see his posts about this amp configuration.
Old 3rd April 2007, 02:25 PM   #34
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
One topology that does work well is where you have a single output transformer with two identical centre-tapped windings. One winding goes from drain to drain with the CT to positive supply rail, the other winding (reversed in phase) goes from source to source with the CT going to earth. Then optionally (but preferably) put a pair of large capacitors e.g. several thousand uF from one drain to the opposite source and vice versa. The speaker is connected from source to source, or from drain to drain, whatever you prefer.
This is an absolutely rock-solid way of making an amp and it is basically an emitter follower so distortion is low and it only needs n-channel devices. Further, the transformer does =not= need to have good audio quality at all. The thread is here
Most of the old timers here would have heard me blab on about it before, but if you haven't it's definitely worth a look. It can easily be scaled up to a seriously big amp.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 3rd April 2007, 03:14 PM   #35
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by lumanauw
Hi, all,
Pafi, you seems to understand much about tranformer. How can I calculate minimum requirement (minimum inductance or resistance) for the ZEN V7-T? Mr Pass himself does not touch this in his article (can be seen in Passdiy). He just use ordinary 120V+120V of 300VA primaries. If I want to DIY this load CT inductance, not using power transformer primaries, how can I calculate the requirement (toward voltage and speaker load)? What will be the number of turns and sizes of the magnet wire?
For 20Hz into 8 ohms you will need 80mH.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Transformer output solid stateHide this!Advertise here!
Solid State amp with output transformers vizion Solid State 32 19th December 2016 04:35 PM
What Solid State Amps with Output Transformer do you know of? Onvinyl Solid State 27 27th April 2010 11:41 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 06:26 PM
Copyright ©1999-2017 diyAudio
