Old 14th June 2004, 01:45 AM   #1
SkyChu is offline SkyChu  Taiwan
Question distortion of SW CAD III
I'm trying to simulate circuit by LTC SWCAD III . But the 3rd (Odd)distortion of input voltage source is too high when I use FFT simluation (V1, see attached files). the transient is ".tran 0 15m 1m 0.1u".
How can I reduce the distortion ?
Sky Chu
Old 14th June 2004, 01:48 AM   #2
The FFT:
Sky Chu
Old 14th June 2004, 03:51 PM   #3
jcx is offline jcx  United States
have you turned off compression? expecting long sims of switching power regulator circuits LtSpice compresses the sim output data files by default - Tools>Control Panel>Compression - clik off all the boxes every time you open LtSpice
more recent versions accept a spice directive:
.options plotwinsize=0
in the fft menu i increase length to 131072 and use the Blackman window, keep averaging low or off(=1) since it is a digital low pass filter appiled to your data - i think mine defaults to 5
Old 14th June 2004, 04:15 PM   #4
DarkOne is offline DarkOne  Slovakia
DarkOne's Avatar
You have feedback attached only to "negative" half of the circuit
Old 14th June 2004, 06:17 PM   #5
Thanks Jcx ! It can work !
Sky Chu
Old 14th June 2004, 06:30 PM   #6
Yes ! Is it "feedback" ? !
Sky Chu
Old 19th June 2004, 08:11 AM   #7
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
Ok! I have a agreement with Darkone
Skychu! you have to feedback attached only to "negaitve" half of the circuit
How to get the less distortion with BJT? dododio Solid State 24 6th September 2008 09:55 AM
Neo 8 distortion? studiotech Multi-Way 4 17th April 2005 05:22 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
op amp distortion zahlm Parts 3 15th May 2004 07:45 PM
Page generated in 0.10085 seconds (69.10% PHP - 30.90% MySQL) with 11 queries
