My amp design schematic
Old 10th June 2004, 08:04 PM   #11
markp is offline markp  United States
Originally posted by sam9
What is a fantastic result?
Gee, lets see... How about better sounding than any commercial product that is within 10 times the cost. I'd think that is fantastic. This amp can be that good if done right.
If it sounds good... it is good!
Old 10th June 2004, 08:04 PM   #12
ergo is offline ergo  Estonia
Originally posted by markp
There are things that are meant to be figured out rather than just shoved at you.
Is one of your teaching goales to show a very odd way to draw a schematic ?
At least in my opinion one should be able to do without splitting such a simple circuit in half....
Ergo
Old 10th June 2004, 08:06 PM   #13
Ergo
If you cant figure out how it goes together then you should not be allowed to play with electricty.
Old 10th June 2004, 08:13 PM   #14
Ooh I do know how to put it together all right.
It's just that if you want that someone can use it as a learning experiance then it is made too complicated for a beginner DIY person. One would most likely drop the analysis because you first have to figure out how the schematics is built up before you can do any analysis on it... in my opinion it's a wrong way to teach amp design.
Actually I would put the VA stage caps in parallel with collector loading resistors not between base-collector. Many say this improves a sound alot.
Ergo
Old 10th June 2004, 08:17 PM   #15
Ergo
If you can't put A to A and B to B then you are right they should not try this project. The Miller caps work fine where they are but if you wish to move them that is what this is all about. Having a place to start and doing it from there your way.
Old 10th June 2004, 08:24 PM   #16
sam9 is offline sam9  United States
sam9's Avatar
"Gee, lets see... How about better sounding than any commercial product that is within 10 times the cost."
Hmm. . . Funny how that's what they all say.
Old 10th June 2004, 08:26 PM   #17
mandat is offline mandat  Poland
Try to place your post in the threat Single or dual differential?.
It is an ordinary amp with two differential input stages. One thing is unusual - the way of transistor drawing. At the first glance at the schematic in black I suppose that you should place your post in TUBES section.
Old 10th June 2004, 08:44 PM   #18
sam9's Avatar
Doing some mental gymnastics to untangle the spagetti it appears to me a highly generic amplifier with symetric topology. It looks like it came out of a textbook.
Old 10th June 2004, 08:53 PM   #19
EUVL is offline EUVL  Europe
Default Exporting Autocad Schematics
You can export AutoCad files as *.wmf, then put the wmf in a power point sheet, and export the power point as jpg or bmp. Not a direct conversion, but can be done in minutes.
Patrick
Old 10th June 2004, 09:05 PM   #20
Default Re: Exporting Autocad Schematics
Patrick
Or you can export it a bmp then convert it to a gif, as I did. And it was done in minutes.
My amp design schematicHide this!Advertise here!
what's best enclosure design for Coral Beta 8 Speaker ? which horn ? Schematic ? calico88 Full Range 34 13th January 2013 07:46 PM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
the best PCB design and schematic for the LM1875? lutherblisset Chip Amps 0 29th October 2004 01:40 PM
Valve schematic & PC board design Athol Tubes / Valves 2 9th August 2004 08:23 PM
Copyright ©1999-2017 diyAudio
