My mystery transformer.
Old 9th June 2004, 02:59 PM   #1
azira is offline azira  United States
Default My mystery transformer.
I found this transformer in some random pieces of an unknown power supply. Clipped the wires and measured up the voltages.
On the left, AC comes in the top 2 terminals.
On the left, bottom three terminals are 32VCT
On the right, bottom 3 terminals are 18VCT
On the right, top two wires are 32V.
What I don't understand is why the top two wires are different. They are made out of it seems some very stiff solid 22AWG wire and covered some a plastic sleeve the slides loosely. They were wired directly to a bridge rectifier that was mounted at the base of the xformer.
Since the flash killed my measurements, it's aproximately 4" x 4" x 2.5". Any idea on the VAs I might expect?
Thanks.
Danny
Old 9th June 2004, 03:03 PM   #2
peranders is online now peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
50-80VA is my guess ,maybe 100 VA
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 18 pcb's in interest so far.
Old 9th June 2004, 03:14 PM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Thicker secondary wires can be brought straight out. Being fragile, thiner ones need to be secured and connected to a tag or a thicker wire for use by us clumsy punters.
Make sure the widings you use are truely secondarys, and are not taps of the primary
Old 9th June 2004, 10:52 PM   #4
I'm paranoid about the mains I checked the DC resistance of the windings to find the taps and make sure there weren't any shorts. The windings are as I mentioned them.
Thanks for the info.
Danny
Old 9th September 2007, 06:42 PM   #5
rasmus is offline rasmus  Norway
Default double barrel amp
hi pics of my super amp
hei å hå
My mystery transformer.Hide this!Advertise here!
Mystery RF amp spooney Car Audio 11 25th April 2008 06:14 PM
Power Transformer mystery lead.... skittletata Tubes / Valves 2 3rd April 2008 03:40 AM
Transformer - mystery VA seventenths Power Supplies 10 5th September 2007 05:47 PM
Mystery transformer Ty_Bower Tubes / Valves 2 15th June 2007 12:24 AM
Mystery SE OPT alexmoose Tubes / Valves 4 11th July 2006 01:29 AM
Copyright ©1999-2017 diyAudio
