Old 8th June 2004, 09:34 AM   #1
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
Default change busted output transistors
In a posting some time ago DJSS wrote:
"I have found a way to QUICKLY identify and change a busted output transistor or an entire channel. In the end, I should be able to replace a busted channel and have the system running again in less than 2 minutes."
I like to kow what he made and if there are others with an easy and fast way to replace a complete power stage in diy-amps.
Of course the amp hax to be designed for it (mechanicaly).
I hate to desolder and solder these output devices, especially if there are 16 or more.
Usualy the pcb tracks get bad after a few tries...
One faulty output TR,change all 4? Aidan135711 Solid State 27 5th September 2008 09:25 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
Can I change receiver output to preamp? sounder Chip Amps 3 27th September 2003 09:26 AM
XLr balanced input/output. How do I change...? Lito Multi-Way 2 20th June 2003 01:45 AM
Change medium transistors... Dj BASS AMP Solid State 32 4th March 2003 09:52 PM
Page generated in 0.36184 seconds (17.61% PHP - 82.39% MySQL) with 10 queries
