#11 | |
What I am saying is straight forward: IF you are of the classification that believes FETs suffer from thermal runaway then a FET Vgs multiplier might be better than a BJT one. On the other hand, iF you are NOT of that classification, then it doesn't matter what you use... Really, how many BJT amplifiers do you see use the same device for the output device AND Vbe multiplier? Not the Citation 12, Not the Leach amp, Not P3A |
#12 |
You still don't get it do you?
"IF you are of the classification that believes FETs suffer from thermal runaway then a FET Vgs multiplier might be better than a BJT one. On the other hand, iF you are NOT of that classification, then it doesn't matter what you use..." Whether it needs it or not is not determined by anyones' opinion, but by the construction of the part. The manufacturers data sheet will show the tempco of the RDS and the Vgs. "Really, how many BJT amplifiers do you see use the same device for the output device AND Vbe multiplier?" If you use the same part then the Vgs tempco will be the same, what does a TO220 FETcost? Maybe $0.50? On CFP amplifiers I always use the same exact transistor I use as the driver, diode connected and in contact with the driver. Look at a Mark Levinson ML3 schematic, that's where I got the idea from. |
#13 | |
to be. If that was the case, why bother putting a heatsink on it? Here's a link that states that power MOSFETS can thermally runaway. http://www.smpstech.com/tmos0000.htm Here's a link to a thread I had a while ago in which the participants couldn't agree what thermal runaway WAS. Will a true class B have thermal runaway? |
#14 |
At the risk of repeating myself:
"Lateral MOS types are the only easy ones to use in a class AB amplifier, they are easy to spot because the Source is connected to the case. Vertical MOS are easiest to use in class A designs, the Drain is connected to the case." That should make it simple for those who can't find or read the data sheet. |
#15 |
Dear all
Your replys were a great help for me. thank you all for you comments and for your help. I will let you know for the results of my amp as soon as possible. Regards George Vasiliou |
#16 |
Yo are right about this. Contrary to public believe FETs run away.
I have experienced this many times at work when we constantly monitor the losses in different transistors during evaluation. The mechanism, however, is different from BJTs but the bottom line are always exploding transistors. This almost deserve a new thread I think. / Regards / Mattias |
| 6S19P Push-Pull Amplifier | sorenj07 | Tubes / Valves | 6 | 24th October 2007 02:59 AM |
| 6BQ5 Push-Pull amplifier | YFW | Tubes / Valves | 6 | 7th June 2007 10:18 PM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Double push-pull versus single push-pull | jraraujo | Tubes / Valves | 19 | 19th October 2002 12:23 AM |
| Page generated in 0.09011 seconds (79.34% PHP - 20.66% MySQL) with 11 queries |
