Old 5th June 2004, 10:09 PM   #1
00940 is offline 00940  Belgium
Default Little fet preamp
I found this little preamp on this website : http://michel.burdin.online.fr/zen.htm#PAFET
it's a slightly modified version of a preamp published in "la nouvelle electronique n°2". Author claims that performance is close to a BOZ. Consumption is about 100mA for both channels.
Any comment on this one ? I'm planning to put it inside a philips cd753, to get a decent variable output.
Old 5th June 2004, 10:22 PM   #2
Default it ain't rocket science...
Looks like it's designed for a certain sound due to its relatively bendy transfer characteristic. Might sound 'nice' though.
Old 6th June 2004, 07:08 AM   #3
You see any way to improve it ?
I've been adviced on another board to scrap C21 and C22
Old 6th June 2004, 08:05 AM   #4
allright, I've been also told the contrary with better arguments
Old 6th June 2004, 11:50 AM   #5
Yes, you certainly need those coupling caps.
Improvements; well not really, it is what it is. If you want better linearity then an entirely different design is required.
If you do build it make sure you use a well regulated power supply.
Old 6th June 2004, 04:36 PM   #6
Devil_H@ck's Avatar
Send a message via ICQ to Devil_H@ck Send a message via AIM to Devil_H@ck Send a message via MSN to Devil_H@ck
This might be a stupid question, but don't you need a negative supply voltage too?
Website: http://members.lycos.nl/anthonyvh
Old 6th June 2004, 04:50 PM   #7
C36 enables both negative and positive output voltage swing from a single rail supply.
Old 6th June 2004, 05:05 PM   #8
Devil_H@ck's Avatar
Ah, ok, thanks !
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Solid State 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
Page generated in 0.08907 seconds (75.26% PHP - 24.74% MySQL) with 10 queries
