Charles Hansen come in please
Old 5th June 2004, 03:53 PM   #1
Wizard is offline Wizard  China
Send a message via MSN to Wizard
Default Charles Hansen come in pleaseŁĄ
Hello, Charles Hansen ,Can you recommend the best of power supply for the Erno_Borbely's
EB-2000/402 SE Balanced Jeft Lineamp?
Thank you very mach.
Old 6th June 2004, 12:00 AM   #2
Charles Hansen is offline Charles Hansen
Hello -
I'm not sure why you're asking me instead of Erno Borbely. This circuit is not the kind of thing that I'd recommend. However, I can make a couple of comments:
1) The power supply rejection ratio of this circuit isn't very good, so its performance will be quite dependent on the quality of the power supply.
2) It is possible to blow the 2SJ74s used in the output stage. These are rated at 25 volts and if the circuit is running up to the clipping point, the full rail of 36 volts will be applied. You might try reducing the supply rails.
Hope this helps,
Charles Hansen
Old 6th June 2004, 12:37 AM   #3
Jocko Homo is offline Jocko Homo  United States
Banned
Default Look at the bright side......
He asked you instead of John Curl.
Jocko
Old 6th June 2004, 03:53 AM   #4
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Default Charles Hansen, help please!
Hi, Charles Hansen,
Why do you say this in Etalon thread
If you want to get rid of the servo, I would also suggest getting rid of the error correction. In my experience you are better off just adding another pair (or two or three) of output devices. This is particularly true for this design as the triple emitter-follower output stage will be able to drive low impedance loads quite well.
I'm very interested with error correction, but your indications are not to use them. Including the comment by AndyC. I have questions.
1. Error correction can improve damping factor. Is applying error correction gives AUDIBLE difference/result (not only measurement result?)
2. I want to use error correction, but also parrareled (4 pairs) or triple emitor darlington output. Is this makes the error correction not worth it ( you compared error correction with parrareled output)
3. Please explain why you dont suggest error correction.
Old 6th June 2004, 03:58 AM   #5
lumanauw's Avatar
Can anyone help, where can I see Halcro design or at least Halcro patent? Some said Halcro uses modified error correction, I wanted to see what it likes.
Old 6th June 2004, 04:23 AM   #6
Hello, Charles Hansen. I thought I have made some mistakes in my words. I mean to find an excellent power supply circuit that is used in Erno_Borbely's EB-2000/402 SE Balanced Jeft Lineamp. Can you give me some recommends(advice)? Thanks very much!
Old 6th June 2004, 04:31 AM   #7
Smile Oooooo
Old 6th June 2004, 04:40 AM   #8
john curl is offline john curl  United States
john curl's Avatar
I built a nearly exact example of this design for the Grateful Dead at Alembic Inc in 1973. It is somewhat dated, but Walt Jung's power supplies should work OK. Be careful about power supply noise, as it can easily get into the design.
Old 6th June 2004, 04:56 AM   #9
Hello ,John Curl.
Can you give me the circuit?
Thank you very mach!
Old 6th June 2004, 05:44 AM   #10
Go to:
http://patft.uspto.gov/netahtml/srchnum.htm
and search under patents 6600367 and 5892398
Charles Hansen come in pleaseHide this!Advertise here!
HP339A article Charles Hansen fmak Solid State 12 4th November 2009 09:36 PM
Please Mr Charles Hansen and Konrad: help! Daneel Solid State 7 1st March 2008 05:18 PM
Please M. Charles Hansen PRP resistor maxpou Solid State 1 30th January 2008 02:51 AM
Charles Hansen's book lumanauw Solid State 3 16th March 2006 07:17 PM
Copyright ©1999-2017 diyAudio
