#71 |
JCX,
To that thought, remember the Speaker grill color tests done in the 80's. (If memory serves) The same speaker was places behind different shaped and colored Grills and people had statistically significantly different perceptions of the sound from the same speaker placed in the same position. If I remember correctly, brown and black grills got the comment, "Dull and boring" from more than one test subject. I am not implying aesthetics are the dominant variable, but it does skew perceptions. K- |
#72 | |
With 35 years of diy audio experience under his belt, he knows at least this part of the subject inside out. ![]() That's why I've decided to take his sage advice and whenever I make anything for either my friends (i.e. their wives SAF) or myself (i.e. my own SAF), I intend to spare no effort on the veneer on the speaker enclosures and the multi-layered PU coats. Who needs accurate xo after that? This probably also explains why the Krells and Halcros sound better in the amps department? You need to be a Peter Daniel to do a good job on metalwork as a diyer, I guess... |
#73 | |
#74 | |
Are all the best designs already copyrighted? Surely audio isnt such an inexact science that a carefully constructed premium design using optimal components may not sound great? As to the Ferrari analogy - the difference is that Ferrari make all their own parts in a factory. Whereas (i'd expect) an amp would be contructed of components available to all. |
#75 | |
#76 |
May i suggest you take a look at this one:
http://www.hilberink.nl/amps/amps5.htm This amplifier has been published in a special publication of Elektor. A smaller version was in the magazine. There might even be PCBś available at Elektor ( http://www.elektor-electronics.co.uk ) But please dont contact the owner of the site !!! Andre Schmeets |
#77 |
Banned
People keep making confusion with power and quality.
What's one thing got to do with the other? Do you need a 1kwatt amp? If so, buy a PA system. Why the example of the Ferrari? Is it the best car in the world? Actually they have fame of being unreliable, you have to spend plenty of money to keep a car like this. Porsche is quite the opposite. But ultimately, it is very subjective, as Audio is: what's the best car in the world? Ferrari? Rolls-Royce? It depends on what are your parameters to evaluate a good car, but I would say the Rolls. Electricity is expensive here. Even not talking of the price of the products, I don't have the money to drive a Ferrari, I don't have the money to keep a big class-A amp always on, but there are always market for this and people who like this things, even if it's just to impress the friends, or to get some girls. |
#78 | |
Ferrari make their own parts because they need precision. Some audio mfrs do this to. Some have bespoke transistors made for them. Most screen parts against strict specifications. The trouble with DIY designs is that they usually specify only to a schematic and part number level. This is no where near specific enough to get audiophile sound, in my opinion. |
#79 | |
The one and only
has actually had custom transistors made for them. They simply seem to have re-labeled them. None of the fabrication houses are going to tool up for the volume of a high-end company, and Harmon, who could conceivably command such a service, apparently chooses not to. While the quality of the parts is important, what you do with them is of far greater interest and consequence. |
#80 | |
Hmm, not a good example, or maybe it is actually a very good example, as it backs up NP's statement. If you take a closer look at a ferrari testarossa, you will find that a huge number of the parts are actually standard Fiat parts..... Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
| Building the ultimate DIY power amp | traderbam | Solid State | 6 | 8th June 2004 10:39 PM |
| Page generated in 0.13437 seconds (80.47% PHP - 19.53% MySQL) with 10 queries |
