diyAudio Moderator Emeritus
What is the best possible unbalance-balance converter using opamp? In RodE's site he's using a cross feedback between 2 opamps (like C). Is this giving better performance than stand alone (B)?
I saw (A) in here. Is (A) possible to make unbalance-balance converter? Maybe I draw (C) wrongly. RodE using 3 opamp. I saw these kind of configuration with 2 opamps, in PDF somewhere in here, but forgot how it looks like, feedback crossing with only 2 opamps. Anyone can help, which opamp pdf datasheet have drawings like (C)? |
#2 |
A has positive feedback, so i'd say not to use it.
B has a lot of resistors. they must be chosen such that the resistors on the bottom opamp are 2x the resistors on the top. C doens't look like it works.
if only it could be used for good, not evil... |
#3 |
Banned
What about just useing a balanced chip ? I ordered a few samples they go from rca to balanced and there pretty cheap.
#4 |
Look at Texas Instrument home page and search Burr-Brown's OPA1632.
The OPA1632 is a fully-differential amplifier from input stage to output stage. It is dedicated to driving high-performance ADCs. FEATURES: Distortion: 0.000022%, Noise: 1.3nV/SQRT Hz, SR: 50V/µs, GBW: 180MHz Supply: ±2.5V to ±16V, Power Shutdown option. The OPA1632 is available in an SO-8 package and a MSOP-8 PowerPAD package. |
#5 |
Account Disabled
#6 |
#7 |
This a copy from a THS4130 datasheet, an older brother of OPA1632. In this case you use one opamp, only.
#8 |
To the unwashed, the 1632 circuit looks similar to the 135 circuit, but close examination shows that it is not.
If you actually intend to send audio any distance down a balanced line, the circuit must mimic a transformer. If you actually intend to receive audio any distance down a balanced line, the receiver must be a transformer. The receiver chips, despite their 0.001% matching of resistors, are up to 50dB worse than a transformer. Those that have been to the balanced line seminar at CEDIA will be familiar with these ideas. |
#9 |
Take a look at these http://www.analog.com/Analog_Root/pr...2142%2C00.html
They work really well in everything I've used them for. Low noise and the ability to drive very long cables. Its an easy one chip solution.
If it sounds good... it is good! |
#10 |
While the SSM2142 mimics the performance of fully balanced
transformer-based solution for line driving, the previously linked to TI/BB DRV135 is an IMPROVED REPLACEMENT FOR SSM2142. The SSM2142/2141 is the SPECIFIC CHIP SET used in the CEDIA seminar showing that this solution can be up to 50dB worse than using a transformer for the receiver. |
| Balanced Driver / Receiver | arigy | Solid State | 11 | 14th June 2010 09:26 AM |
| Fully balanced Opamp | rkn | Pass Labs | 21 | 29th August 2008 06:21 PM |
| opamp driver stage | Acoustat | Solid State | 11 | 22nd February 2005 10:09 PM |
| Balanced Line Driver | Jerry Parker | Everything Else | 1 | 1st April 2003 05:32 PM |
| rod's balanced driver & receiver | hugobross | Solid State | 2 | 19th March 2003 08:36 AM |
| Page generated in 0.12954 seconds (76.44% PHP - 23.56% MySQL) with 11 queries |
