Old 3rd June 2004, 11:06 AM   #1
Default 1 kohm volume pot
I'm looking for a high quality 1kohm volume pot (log taper, dual or quad). All the good pots are high-impedance (10k and up). Has anyone seen such a device?
Bruno
Old 3rd June 2004, 11:42 AM   #2
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
Hi Bruno,
Somebodys having a noise “issue”
Try Spectrol 180 Series,
Farnell P/N 307-1133 or 307-1250 1K Double Gang Log.
After major QC issues with Log Pots, the tracking between Gangs can be very poor due to the Log Taper, I now use LIN pots and an extra resistor to emulate a Logarithmic like taper – I find its Ok for most applications.
See below and original design idea:-
John
Life shouldn’t be take it too seriously, you will not come out alive anyway…
Old 3rd June 2004, 11:43 AM   #3
JohnW's Avatar
And original design idea:-
Old 3rd June 2004, 11:54 AM   #4
Yup, that's probably going to be the soundest way out. Thanks.
Old 20th July 2004, 11:04 AM   #5
Hi Bruno,
Making a log potmeter with a lin potmeter + adding a resistor does not work very well due to the non linear resistance on the taper. The larger the current, the worser the effect.
Once I tried wirewound potmeters, which seems to work well exept that they are very hard to get in stereo. you need to make a mechanical connection between them to have dual or even quad configuration.
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
set volume with 50k Pot on Zen V4 cHab Pass Labs 2 17th June 2008 12:49 PM
sub volume help jpark Car Audio 0 3rd April 2006 09:16 AM
Amp volume Atic Parts 2 27th February 2005 06:30 PM
Low volume, even when set to max Bong_water Digital Source 0 20th April 2004 08:43 PM
Page generated in 0.08355 seconds (71.39% PHP - 28.61% MySQL) with 11 queries
