Old 2nd June 2004, 10:21 AM   #1
Default dumbish question
Pardon my ignorance, but can someone explain why values such as 221 ohm 22.1 ohm 221K ohm etc for example are nominated on circuit diagrams, standard values , here in Oztralia standard available values are typically 220 ohm, 22k ohm etc.
I assume that such variations from the nominated circuit values are typically not critical
If I were to go and ask for a 221 ohm resistor etc. I’m sure I would get a “kangaroo in the headlights” look from the sales assistant.
Thanks in advance.
george a
Old 2nd June 2004, 10:29 AM   #2
This is depending upon tolerance. 221k would be typical for a resistor with a tolerance of 1%.
So if the shop carries these there won't be any strange look on the face of the salesman !
Charles
Old 2nd June 2004, 10:46 AM   #3
djk is offline djk
djk's Avatar
Parts have a value sequence, a number of values per decade depending on their tolerance.
%10 parts have 12 values per decade
%5 have 24 values
%1 have 96 values
http://lalena.com/audio/electronics/color/
Old 2nd June 2004, 11:13 AM   #4
Ouroboros's Avatar
These are E96 range values. Sometimes (usually with designs from the USA for some reason) designers specify E96 values where standard E24 parts are quite adequate, so you see 221R instead of 220R (for example).
You'll have to rely on your experience and knowledge to know if the E96 values are critical.
Old 2nd June 2004, 11:17 AM   #5
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Have a look at this table
\Jens
Old 2nd June 2004, 12:21 PM   #6
Electrons are yellow and more is better!
peranders's Avatar
Default Re: dumbish question
Originally posted by george a
Pardon my ignorance, ...I’m sure I would get a “kangaroo in the headlights” look from the sales assistant.
Thanks in advance.
We are nice people here so feel free to ask anything
/Per-Anders (my first name) or P-A as my friends call me
do i REALLY need a crossover?? and an amp question. and an ohm question legendaryfrog Multi-Way 4 29th October 2006 01:39 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.08308 seconds (79.24% PHP - 20.76% MySQL) with 11 queries
