SRPP (something like in the world of vacuum tubes) in solid state audio aplications - Page 2 - diyAudio
Old 3rd June 2004, 11:22 AM   #11
Bricolo is offline Bricolo  France
Bricolo's Avatar
Can someone explain me briefly what SRPP is?
Old 3rd June 2004, 11:36 AM   #12
Andypairo's Avatar
Default Re: SRPP
Originally posted by Bojan Hajdinjak
I'll send you by the mail ( its from the internet....)
May I ask a copy of it?
my email is pirobrothers(at) tin.it
Cheers
Andrea
Old 3rd June 2004, 11:40 AM   #13
Default SRPP is...
Shunted Regulated Push Pull or Series Regulated Push Pull.
It's not Push Pull like we know this. In the case, it's A class design with one FET (or triode valve) in class A amplification stage and with another FET (or valve) in the function of adjustable anode (drain) resistor. It's one of electronic designs (circuits), something like by motor cars with Diesel Ottos or Wankl motors,....
This design is a par of the best triode constructions in High End audio an now (www.hiendfi.com) we can find something of this also in solid state world...
You have plenty of this on the internet (but only regards valves, trides,...)
On this page http://www.hiendfi.com/modules.php?n...rticle&sid=102 you can see something of this, no one newer published nowhere...., something unique..
www.hiendfi.com
www.hajdinjaklabs.com
Old 3rd June 2004, 11:44 AM   #14
Default Re: Re: SRPP
Cheers
Andrea
Ok. I hope to understand your mail adress.
Anyone who want this, please send me mail on the info on www.hiendfi.com
www.hiendfi.com
Old 3rd June 2004, 11:47 AM   #15
Ouroboros's Avatar
SRPP effectively combines a high-impedance load for the first stage, together with a low-impedance drive (like a CF) to the next stage. It's one of those design techiques from decades ago that was suddenly 're-discovered' in the 1980s.
Not really applicable to solid state as it's better to use a current-source load followed by an emitter follower. (IMO of course!)
Now the White follower is something that works superbly with SS. It is especially good as the output driving stage on a pre-amp.
Old 3rd June 2004, 11:49 AM   #16
Default SRPP with JFETs and with Valves
For the compare..
Here you have picture of typical SRPP with FETs
and with valves (look on the inpust stage)
www.hiendfi.com
Old 3rd June 2004, 12:15 PM   #17
Bricolo's Avatar
I think this has been asked before, but isn't an Aleph some kind of SRPP?
Old 3rd June 2004, 12:36 PM   #18
Default SRPP
No, it's not
www.hiendfi.com
Old 3rd June 2004, 01:51 PM   #19
Bricolo's Avatar
I only had a brief look on the schematic you posted here as a picture, and from what I saw, SRPP is an active device biased by a current source. The "special thing" is that the current source is setting the current according to the output voltage.
am I wrong?
This isn't so far away from Alephs or JLH
Old 3rd June 2004, 03:21 PM   #20
Default SRPP
It's not so simple.
One is technical and another is sonical vuew on amplifier design
There are plenty of different SRPPs...
www.hiendfi.com
Germanium in the World of solid state (preamps) Bojan Hajdinjak Solid State 115 11th May 2015 05:05 PM
World Solid-state Diy Build-off! vdi_nenna Everything Else 2 27th December 2004 08:09 PM
ESL amp: tubes vs solid state: where is the winner? Milo Tubes / Valves 43 28th April 2003 09:51 AM
Solid state guy found some tubes... OliverD Tubes / Valves 9 31st December 2002 03:03 PM
Discussion of Solid State vs. Tubes EternaLightWith Solid State 34 30th August 2002 05:33 PM
Copyright 1999-2017 diyAudio
