retro marantz
retro marantz
Old 1st June 2004, 01:35 AM   #11
karma is offline karma  Canada
karma's Avatar
last one
http://www.karmaelectronics.org
Old 1st June 2004, 06:17 AM   #12
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
Is that an old Apple II floppy drive enclosure? Or is it an 8" drive case? I can't tell but from the comparison with the aluminum tool case on the floor which should be about 3" thick, I'd say it was an 8" drive enclosure.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 1st June 2004, 11:19 AM   #13
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Marantz have some secret that i could not find where is it!
I had entire catalogue of model 2270... our friend in forum gentle offers to us to go there and have some schematics.... unfortunattelly now he is asking some money because expenses is becaming to big to keep the whole thing working.... this way you are free to download 10 Megas..... but schematics are 5 to 6 Megas some of them (hohohô).... this way, if you pay 5 Bucks no problem... can download what you want.
I made board exactly the same as Marantz made.... and, this is not normal, i gonne out into the commerce and i bougth exactly transistors they used... and i heard one 2270 model with one channel better than the other....openned i found modern transistors replacing the ones that have code numbers on it (grumpf!...grrrrrrr!).. are those more famous that toshiba stop to manufacture... do not remember names...150 Watts and 15 ampéres units.
Then i assemble, because of the bass...only the bass.... mid and highs no good for me...only bass!
I had not bass!...loose bass alike Leach amp.... then i look again and again the real amplifier to see if some diodes are germanium.. to see if resistors are really condensers.... to see if resistors measure different related the values informed, and checked whole amplifier again. could not find.
Then i go with both amplifiers, mine and Marantz real unit to laboratory.... to look wave forms, do not trust in my computer or entirely in multisim from workbench..... this way i could see that Marantz distorted a little bit more, and have some harmonics greater in Spectrum analiser....but voltages the same, differences not more than 20 percent... iddle current, bias setting the same, off set mine bigger than Marantz... could not understand...those two flat amplifiers....no difference when tone bypassed
I change input electrolitic from mine to the marantz and return home.
And i put them to work and same power with i Kilohertz signal... and flat... same speaker.... switch on to other and same music from a DVD player with higher sampling frequency....mine stay week in bass, Marantz better in bass, same speaker....
Then i change speaker.... remains the same sittuation.... then i send it again to 16 ohms.....remains the same.
My Marantz was dismounted... real Marantz returns to owners hands, and i forget marantz circuit bass because it over charge my brain too much.
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 1st June 2004, 11:34 AM   #14
karma's Avatar
ensen.
not sure it just had a model number on it. some kinda digital tape drive. or part of one anyway
cy-8505
http://www.pacificdata.com/cy-8705.html
Old 1st June 2004, 12:16 PM   #15
karma's Avatar
this is what the front will look like if i can get around to finishing it
its going to have wood on it somwarez
Old 1st June 2004, 12:19 PM   #16
karma's Avatar
Default .
this or a wood face ahh the $5 case
Old 1st June 2004, 03:10 PM   #17
If you take the paint off the alum case with a wire brush or sanding disk, you will have a higher end look. Practice on a piece of scrap first and you will see. Of course, that assumes that the case really is aluminum and not some steel alloy. If alum then it will auto-anodize after brushing. If steel, it will rust - yuk!
Nice job on the metered look.
:)ensen.
Old 1st June 2004, 08:02 PM   #18
Default White is wonderfull too.
But is hard to keep it clean. When time passes it becomes yellow in my hot country.
Carlos
Old 5th June 2004, 01:26 AM   #19
karma's Avatar
lights work
not to shabby for a fast case
its missing a rivet
Old 5th June 2004, 01:37 AM   #20
karma's Avatar
Default .
retro marantzHide this!Advertise here!
Found retro 80s amp - Anyone know what this is? tiffin4tea Chip Amps 7 15th February 2009 02:16 AM
Balance Pot, (=retro?) Cobra2 Everything Else 2 1st December 2003 09:25 AM
