Old 31st May 2004, 02:46 AM   #1
Sarge is offline Sarge  United States
Default NAD 2400 popping noise
Help!
I have an NAD 2400 that makes a loud pop through the left channel only when turned on (each time). After this the amp function normally with no other problems.
Any suggestions?
Sarge
Old 31st May 2004, 03:46 PM   #2
jaycee is offline jaycee  United Kingdom
Maybe there is a relay per channel for DC protection/startup thump prevention and one of them has a stuck contact ?
Old 31st May 2004, 04:16 PM   #3
Default NAD 2400
Well...? Actually it takes about 5 seconds to occur and does not make a low freq. thump, but more like a static spark (if that makes sense)
Sarge
Old 8th May 2006, 12:38 PM   #4
steven344's Avatar
Default nad 2400
These amps have alot of bad solder connections after they have been used awhile,also check the regulators near the front of the circuit board,the caps there dry up and the tops look like they are ready to open 1000 mfd at 50 v.I have the manual if you need it
popping and static noise in an Altec 1592A lassoharp Solid State 7 14th March 2009 02:25 AM
Amp causing popping noise? guitarguy12387 Car Audio 7 15th April 2008 01:58 AM
popping noise through 1 channel on Radford STA15 jives11 Tubes / Valves 5 28th September 2007 07:44 PM
Popping Noise = Clipping ? liggs17 Tubes / Valves 5 28th November 2006 07:16 PM
Question about popping Noise Derrick Tubes / Valves 5 27th February 2004 10:34 PM
Page generated in 0.07084 seconds (71.81% PHP - 28.19% MySQL) with 10 queries
