Anyone know this audio opamp?
Old 29th May 2004, 08:46 PM   #1
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Anyone know this audio opamp?
Hi everybody,
I stumbled across the MC33078 from ONSEMI. This is an intriguing opamp, ostensibly developed specific for audio. For one thing, it has an output stage that appears to be class A, or at least non-switch off.
Although the open loop gain shows the familiar fall off from 100Hz for a run-of-the-mill opamp, the THD curve is almost flat to 100kHz! Also the CMRR is flat. This combination is unusual.
If you look at the representative circuit, there is a complex output stage. Some feedforward capacitors I think, and the diodes have some function in the output stage biasing.
Two questions I have:
- Can anyone explain how this output stage functions?
- Any experiences? (I'm listening to a pair as preamps now, sound not half-bad).
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 29th May 2004, 09:06 PM   #2
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
I know them, they're nothing special soundwise. Most modern known audio-opamps sound better. I replaced them often in gear, I forgot what gear. Maybe Rotel preamps.
Can't comment on the output stage although it seems no more or less complex than found in most opamps. At least what the manufacturer wants us to see in the simplified diagram
It's only audio. Member of the non modular PCB design committee
Old 29th May 2004, 09:34 PM   #3
jan.didden's Avatar
Yeah, it always says 'simplified diagram' or 'representative diagram'. But this output stage does look a bit more involved than the standard totem-pole or quasi-complementary stage. It does intrigue me.
So, you don't think it is too hot. What do you normally replace it with?
Jan Didden
Old 29th May 2004, 09:44 PM   #4
moamps is offline moamps  Croatia
Some expensive AMEK audio consoles use this chip (probably because very low noise) mixed with 5532 and 072.
Old 29th May 2004, 11:51 PM   #5
andy_c is offline andy_c  United States
Banned
Interesting op-amp.
It looks like the reason the distortion is nearly independent of frequency is they're using Cherry's trick of enclosing the output stage in the Miller loop via C2. So the local feedback from C2 increases at the same rate the global feedback is decreasing, giving nearly constant distortion vs frequency much like VAS distortion in a power amp. Then at higher frequencies input stage distortion starts to dominate I guess.
It looks like Q7 performs current limiting, as does Q3. I can't figure out what C3 is all about though, or how the bias currents in Q8, Q10, Q11 and Q12 are set. I guess if Q10 and Q12 have the same emitter area, they'll have the same emitter current. Maybe R6 determines how the DC current of Q9 gets split between Q8 and Q10? Also, it looks like the DC current in R7 is zero, assuming the D3 drop and Q11 Vbe are the same. It looks like D4 is normally off.
It is pretty baffling though, isn't it?
Anyone know this audio opamp?Hide this!Advertise here!
best TI audio dual opamp Leolabs Chip Amps 8 14th April 2014 09:40 AM
Best OpAmp for Audio Alchemy DITB arupg Digital Source 79 12th February 2014 09:51 AM
Best opamp for audio, operating at +5V only trodas Parts 4 21st August 2008 06:34 AM
Audio CFB Opamp jackinnj Solid State 8 28th November 2007 07:44 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
