#11 | |
sreten.
#12 |
The LV OP runs till it is close to it's rails then the TA2031 switches the audio signal to the higher HV OP stage.
The switching is such that they never conduct simultaneously. It is also not that the LV OP's handle a clipped signal and the HV provides the additional "crest" of the sinewave, but that lets just says that given a single cycle of a sinewave, and assume it represents a bell shaped curve, 2 standard deviations are handled by the HV OP and the rest by the LV OP stage. The obvious advantage is that no set of outputs sees greater than +/-50 vdc or so across their CE's so dissipation is very low. K- |
#13 |
so under HV the LV will be reverse bias, eliminating V drop over output devices (i noted theese large diodes)
.:Ride the Lightning...Feel the Thunder:. - Technics Triple Thunder www.welcome.to/Technics oh yes ppl plz send me them dead (or Alive) STK or SVI ICs
#14 |
I have the Kenwood Basic M2A Service manual that I have scanned at 600dpi and burned on CD. I list this on eBay from time to time. If anyone is interested, I can relist it.
#15 |
Lookie here, If it isnt my old buddy Dan!!
![]() Hows it going? - Arif. |
#16 |
hi all,
does anyone here have a M2A manual? cheers - neil |
#17 |
Hi.
Here M2A. GEirin |
#18 |
hi.
#19 |
OK.
#20 |
OK
| Kenwood Basic M1 Amplifier | Rte 66 Dave | Solid State | 22 | 27th June 2012 01:10 AM |
| kenwood basic m2 amp-circuits | collumbo | Chip Amps | 7 | 4th January 2012 09:01 AM |
| Kenwood basic m2 | Johnny25 | Class D | 0 | 20th January 2006 06:48 PM |
| Book for basic circuitry in amp building? | kneadle | Chip Amps | 2 | 8th October 2004 01:26 AM |
